jwolk1's Avatar
Help! New Wrench says there could be a problem with differential -
The former mechanic shop that I used to service my 1983 944 closed down, so I am trying out a new wrench for a state inspection and oil change as of this morning. The shop seems reputable and works on Porsche, Ferrari, Audi and Benz - a step up from my former mechanic - he seems knowledgeable and honest. He just called, however, and said that while he was taking a test drive he heard a loud high pitched noise from the rear, which I honestly had not noticed myself. I haven't been driving the car regularly due to the weather and I just installed a new set of rear speakers so I have had them turned up when driving. I am trying to figure out if he is trying to take me or not. I have read other posts, but:
What type of noise would the differential in need of repair make?
What would be some of the other symptons?
In other posts, it has been suggested that a differential may be repaired by the bakc-yard mechanic - so how much should this cost?
Thanks alot -
Jeremy
1983 944
Jeremy
2005 Cayenne S
2001 996
1986 951
Old 04-22-2003, 11:33 AM
My 951 has been whining for several years in 2nd and 3rd. It's going to keep whining until it breaks. Then I'll have it rebuilt.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-22-2003, 12:29 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
I have a wind in first gear with my newer tranny, but I don't even worry about it. Mine is just my R&P being pissy. Find out if yours makes the sound in one gear or every gear. I wouldn't worry about it unless it does it in everygear.
BTW-My old tranny made a weird sound on decell. But that was with the crack R&P, cracked spider gear, and a broken carrier; basically a BIG oops on my part.
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 04-22-2003, 12:37 PM
AFJuvat's Avatar
Some whining is considered normal - a good gear oil can help.
Excessive whining and or groaning could be bearings.
I would bute the bullet and get some Swepco (avail here at pelican) It is really good stuff - a little pricy, but very good. Drain tranny - observe what comes out - some silvery dust is normal, chunks are bad.
refill with the good stuff and re-evaluate
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-23-2003, 12:11 AM
I bit the bullet and put Mobil 1 in my tranny a couple of weeks ago. The 1 to 2 shift is smoother now.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-23-2003, 05:13 AM
Roger Hall's Avatar
I went with AF's advise and used swepco. The trany got alot quieter. I am not sure but I have heard that whining is caused by a cracked ring gear. Mine whines in first at low spead I am not worried about it.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 04-23-2003, 04:18 PM
Dave951M's Avatar
Rear torque tube bearing? This car is 20 years old.
Dave951M
86 951 Blitzwagen
82 931 Basket Case (for now)
Old 04-24-2003, 07:43 AM
