LinkBack | Thread Tools | Rate Thread |
Help! New Wrench says there could be a problem with differential -
The former mechanic shop that I used to service my 1983 944 closed down, so I am trying out a new wrench for a state inspection and oil change as of this morning. The shop seems reputable and works on Porsche, Ferrari, Audi and Benz - a step up from my former mechanic - he seems knowledgeable and honest. He just called, however, and said that while he was taking a test drive he heard a loud high pitched noise from the rear, which I honestly had not noticed myself. I haven't been driving the car regularly due to the weather and I just installed a new set of rear speakers so I have had them turned up when driving. I am trying to figure out if he is trying to take me or not. I have read other posts, but:
What type of noise would the differential in need of repair make? What would be some of the other symptons? In other posts, it has been suggested that a differential may be repaired by the bakc-yard mechanic - so how much should this cost? Thanks alot - Jeremy 1983 944
Jeremy 2005 Cayenne S 2001 996 1986 951 |
My 951 has been whining for several years in 2nd and 3rd. It's going to keep whining until it breaks. Then I'll have it rebuilt.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
I have a wind in first gear with my newer tranny, but I don't even worry about it. Mine is just my R&P being pissy. Find out if yours makes the sound in one gear or every gear. I wouldn't worry about it unless it does it in everygear.
BTW-My old tranny made a weird sound on decell. But that was with the crack R&P, cracked spider gear, and a broken carrier; basically a BIG oops on my part.
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
Some whining is considered normal - a good gear oil can help.
Excessive whining and or groaning could be bearings. I would bute the bullet and get some Swepco (avail here at pelican) It is really good stuff - a little pricy, but very good. Drain tranny - observe what comes out - some silvery dust is normal, chunks are bad. refill with the good stuff and re-evaluate AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
I bit the bullet and put Mobil 1 in my tranny a couple of weeks ago. The 1 to 2 shift is smoother now.
I went with AF's advise and used swepco. The trany got alot quieter. I am not sure but I have heard that whining is caused by a cracked ring gear. Mine whines in first at low spead I am not worried about it.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Rear torque tube bearing? This car is 20 years old.
Dave951M 86 951 Blitzwagen 82 931 Basket Case (for now) |
