Send a message via Yahoo to Cebu
Post No Starter/Engine rotation
1985.5 944na..Turn the key,no starter sound only buzzing sound from right rear. Call tow truck. 2-hrs later tow truck arrives, turn key, vehicle fires up instantly. Go home,tried starts at home (8 start-ups), ninth time no starter activity. Car idles and runs smoothe and strong after starting. No work accomplished since March 2001 xmission o'haul. Please advise
Old 08-17-2001, 02:49 PM
Banned
Post
DME realy
Old 08-17-2001, 02:52 PM
AFJuvat's Avatar
Post
Either your DME Relay or your solenoid is shot/in the process of dying.
AFJuvat
Old 08-17-2001, 09:41 PM
EuroSpecPorsche944
Guest
Posts: n/a
Post
Cebu and I have the same problem from the sounds of it. So where the hell is the DME relay???? I need to replace mine.
Old 08-17-2001, 09:44 PM
Post
Cannot be DME relay. You can remove this relay and engine will still crank.
(good idea when doing compression test)
Probable cause is either bad starter motor,
no power to starter from ignition switch or
possibly battery/cable problem.
Check the ground strap to engine too, especially if you had a clutch job done recently.
Old 08-18-2001, 03:13 PM
Post
Hey Britwrench,
Do you know if a bad DME relay can cause a cold-start problem? My '89 944S2 takes about four sessions of cranking before it finally fires when cold. When warm, it takes about two tries. Could it also be (or more likely be) dirty injectors or a weak coil? Thanks in advance!
Old 08-18-2001, 04:05 PM
88_944's Avatar
Post
Cebu, I think it's your check vale on the fuel pump. The gas is going back to your gas tank. You might need a new pump.
PORSCHE There is no Substitute!
My 944 Site! http://www.skybusiness.com/dean/
Old 08-18-2001, 04:19 PM
Post
The Dme should be replaced every 4 years or so as it causes all sorts of running and starting problems. You will have to make some basic checks on your S2 before replacing any parts.
1. check fuel pressure when cold
2. check compression/leakdown
3. check condition of all ignition parts.
If it runs rough from cold start for a few seconds, check and maybe replace the coolant temp sensor and check operation of the O2
sensor.
Regarding the fuel pump..if the pump was not running, how would it stop engine cranking?
Old 08-19-2001, 11:24 PM
Post
Found the cause..Faulty starter (OEM)1985.5 8/85 944na.
Old 08-20-2001, 07:10 PM
