AllPorsche944's Avatar
Porsche Crest I am afraid to ask, but....
A couple of days ago I replaced the rear brake caliper hardware and pads...While the car was in the air, I took a look at the tranny and noticed it was caked with a lot of gunk, oil , whatever, at first I thought I should pull it and just replace the seals all the way around as it is a strong unit....But then when I was under the car today (as usual) I noticed that the housing of the tranny that bolts up to the Torque Tube has a chip out of it about the
and 1.5" across and half moon in shape...I guess sometime along the way a rock or something must have hit it hard enough to chip a piece of the casing right off....Question is what now? Do I replace the tranny with a rebuilt unit or do I pretend I did not see it and wait until I have real issues with it...There is a bit of fluid seeping where the chip is....CRIPES!!!!
Any advise?
88 944na = Azure Blue
New Rebuilt Race Engine (@190 HP)
Lindsey Racing Fuel System
MSD Ingnition System
Zimmerman XDrilled Frt/Rear
BB Headers & Cat Back Exhaust
Mass Flow Air w/ Ingen Technology
Nology Pro Fire Wires & Coil
Millie Cup Wheels and Kuma's
Old 09-08-2004, 04:54 PM
TCMdocs944's Avatar
Wierd.
I would fashion some sort of cover and put it over it (or just use a sock).
Then I would pretend it wasn' t there until something happens.
Wierd..... what is it made out of? ie..is it weldable?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 09-08-2004, 05:00 PM
TCMdocs944's Avatar
I bet a muff shop can weld it up for you really cheap.
If you can stick a magnet to it, it can be welded easily. If it is aluminum..you may have to take it elsewhere.
Old 09-08-2004, 05:10 PM
Wolf1's Avatar
Re: I am afraid to ask, but....
Any advise?
Any chance of getting a picture? Depending on where it is broken, you may be fine.
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 09-08-2004, 06:09 PM
Did you check the fluid level in the tranny? I can think of all kinds of possibilities but more information would really help a lot.
Nigel
'87 924S 5sp
Slowly recovering from a warped head
Old 09-08-2004, 06:32 PM
speed's Avatar
J.B. Weld
1985.1 944n/a
Old 09-08-2004, 07:41 PM
fast924S's Avatar
Send a message via AIM to fast924S
The tranny casings are Alloy, makes sure you keep checking your fluid, Also you might be able to JB weld it like Speed said.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 09-09-2004, 06:15 PM
