speed sensor
does anyone know if you broke a speed sensor on an 89 944 make it not run?
Absolutly.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
thanks. Imjust replaced the clutch. i had to beat one of the sensors out. i have a new one ordered but it ain't in yet..ssigh. so i can;t test my new clutch. I must add the clutch job was fun to say the least.
89 944 na Dove Blue Metalic 2000 chevy silverado 2000 chevy 454 dually black 79 GMC short bed 4x4 4 quarter horses 89 acura legend GS sedan |
I had to remove the bracket to get the clutch housing off. then i had to drive the sensor out to remove it......it was really stuck. I did mark the position of the sensor bracket before I removed it. Do you reckon it will be close enuff?
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
