few q's about installing driver side window
OK, so i just got my window in the mnail, thanks my924gtc, i removed the panel and found this white sheet of plastic on the inside... what is this... do i need, it's a little tattered and was held on in some places by duct tape. also, do i just drop the window in the door or do i have to mount it up to whatever it is that the power windows move. thanks.
My dad says the plastic is for moisture protection, and now that i got some of the old glass vacuumed up, i can see the lever that the window mounts up to, but do i just slide it in there or is there something else i have to do to insure it stays in? Is it easier to install with the [non-existant] window in the up or down position?
Old 06-03-2005, 04:19 PM
AFJuvat's Avatar
You will need to loosen the window regulator to fit the bottom of the window rail into the regulator.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-03-2005, 05:46 PM
