Is there anyway to touch the pin contacts with a wire to open and close my power window motor..I cleaned my toggle switch contacts to no avail..Before I messed with it, the window was working (slow) but at least it opened..
did you put the switches back together correctly? if you reverse one or both of the contacts, the switch will not work properly
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
the 5 pins on the toggle swith will only go in the harness one way..I,m now thinking that the power motor is shot, but I still would like to short the switch so I can see if the motor will work at all
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
thanks So Cal I,ll try jumping the pins and see what happens..
i meant actually taking the switch apart, as in exposing the innards, not just taking the switch out of the retainer.
Un Chien Andalusia
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
Thread Tools | |
Rate This Thread | |
