16v engine conversion - Ignition control module
I'm looking at putting a 16v engine in my 944na. I have found an engine and the seller will provide: Engine, exhaust, wiring harness, DME, AF, Ignition control module, & flywheel. Is there anything else I would need?
2nd question. Does the 944 na have the wiring harness that the ignition control module plugs into or do I need to get that wiring harness as well? |
I would get the wiring harness too JIC. You might not need all of it but you will need some of it.
I'd get an electronic speedo and I'd look into how you're going to control the heating, as the locations/actuation is different 8v?16v. Those were the PITA when I dropped the 3L into a 924S.
Best Sean
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain |
