Send a message via AIM to hpaulb
Wiper problem
Anyone seen problems with the wiper stopping in the wrong position. Doing it all the time now. Intermittent or just turning them off, they stop pointing straight up. Is this a motor or linkage or switch in the steering wheel problem?
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 01-20-2010, 06:46 AM
Custom User Title
mikepellegrini's Avatar
I know they do that if you put the wrong relay in - perhaps your relay failed?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 01-20-2010, 07:27 AM
white944cup's Avatar
Are you saying that they were working OK, and then they just began stopping in the wrong spot? If so, it's possible that the 13mm nut that secures the bell crank to the gearbox output shaft has loosened up and allowed the bellcrank to move. Try loosening up the nut with a wrench, move the wipers to the desired stopped location, and then tighten up the nut.
1988 944 Turbo
Guards Red - Black Leather
Autothority Stage 2 Chip Set
Weltmeister Strut Tower Brace
1984 944 - Sold to rcecale
Old 01-20-2010, 03:02 PM
I'll try to explain a little more. I have no pictures of the hardware so not sure what the parts are that are refered to.
On intermitant wiper, they seem to work fine and resting spot is down in the correct position. If I have them on either speed of consistant wipe and turn them off, they always stop pointing straight up??? Then I just have to keep tapping the lever till there down.
98 BMW 740i
Old 01-21-2010, 08:11 AM
Bad wiper relay.
Good luck, George Beuselinck
Old 01-21-2010, 08:30 AM
OK, going back to this problem. Stored for the winter so i have time. How can it be a relay? It doesn't control position, only on or off. When ever i use it it stops half way up the windshield. Only on intermitant wiper does it go all the way down to the correct position.
98 BMW 740i
Old 11-04-2010, 11:17 AM
Wow, winter lasts from January through September... Now is the time to change locations.
Old 11-04-2010, 01:40 PM
Redline Racer
HondaDustR's Avatar
The wiper relay is pretty complicated and has the intermittent timer circuits as well as the relay. The circuitry inside also manages making sure the wipers park in the right spot using the contacts embeded on the big gear inside the wiper motor to keep track of position. If any wiring or contacts going to the wiper motor positioning are iffy, or if the circuitry in the relay is bad, weird things will happen. Mine randomly wacked out and ran without turning them on, or not running when I turn them on. I just took the relay out and they have been completely manual for several years since I never took the time to figure out the wiring and never got around to getting ahold of a known good relay.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-04-2010, 09:12 PM
Were is the relay located?
98 BMW 740i
Old 11-09-2010, 07:20 AM
ernie9944's Avatar
If the relay box is located under the dash on your 87 (wiper relay will be X -10)
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 11-09-2010, 08:11 AM
