944 hatch problem
Hi all - new member here from, you guessed it, London. Pic of my Porsche below by way of introduction, and very well it's done me too for the last two and a half years. I did have one issue you might be able to help me with.
The left rear hatch pin no longer locks in place. Peering into the hole it looks like an element of the locking ring has come adrift, which would explain the lack of lockability. Has anyone else experienced this? And is it possible to replace the whole 'female' element of the lock, which looks like it can be unbolted from the rear panel. With all these damn speed bumps here in London, driving it has to be putting pressure on the other pin.
Thanks hugely.
Old 02-08-2010, 10:05 AM
Griffinroydonal's Avatar
The amount of dirt and debris that collects in that part will scare you. The lower catch is easy to remove with two nuts each side. Clean it out and lube it and reinstall. I have replacements if yours is broken
Remove #27 and #26 will fall into your hand when you move the release stem.
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 02-08-2010, 12:55 PM
are the two halves of the lock ring stuck in the "in" position? if so, then it's just dirt. just clean it out like griffin suggested.
if the two halves are moving freely by hand then u need to adjust the pin so it reaches in more. it's a 13mm wrench if i remember correctly.
Old 02-08-2010, 01:08 PM
Thanks for the replies. The locking ring is permanently pushed out, so it might just be grime. I'll have a go at (carefully) dismantling it to see if it's stuck. Otherwise it's new-part time.
Old 02-09-2010, 12:19 AM
Oh and Griffin, do you have a larger version of that picture? Much appreciated if you could send it/link it to figure out all the bits. Thanks
Old 02-09-2010, 12:21 AM
This vendor has every used part on earth and the best exploded diagrams - Shameless plug He helped tons of Porsche cars back from the dead. I try to buy from our host for all new parts he carries but know Robert has a huge inventory of the hard to find used stuff.
dC AutomotiveOver 140,000 square feet of new and used Porsche parts
Old 02-09-2010, 01:26 AM
Thanks for that, but scary shipping costs. Rear lock $35 - shipping $40! Think I'll use the exploded diagram to guide myself to fix it.
Old 02-09-2010, 07:20 AM
Get in the back, pull the carpet back and you will see the two latches... they are held on with 10mm nuts.... Pull those nuts off and you will have the latches... My best advice would be to take them off the connecting rods and clean them in hot soapy water.... Get them functioning properly and then lube them back up and reinstall...
Old 02-09-2010, 10:17 AM
if you over tighten the 2 10mm nuts, Ive found it pinches the locking mech. and will give you trouble.
-1986 944 NA
Old 02-09-2010, 11:18 AM
Great - thanks for all that. I'll have a bash on the weekend and let you know how it pans out.
Old 02-10-2010, 01:32 AM
Excellent. All it took to release the locking ring was to loosen the 10mm nuts. A bit of WD40, tighten the nuts and voila. Very useful 10 mins that. Thanks for all your help guys
Old 02-13-2010, 06:06 AM
ernie9944's Avatar
Welcome on Pelican Londonlux ,as you can see hold bunch of very helpful peoples here,is your car Platinum Metz if so I had an 83 same color if you click on my garage you'll see old faithful, could you send use more pics if you got some.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 02-13-2010, 06:38 AM
Same colour as your old car - for some reason I think it's Sahara Beige (best name for gold I've ever heard). Interesting mods on yours, but you Americans really do lose out on licence plate location don't you!
Another pic of mine - taken outside my local 'under the arches' Porsche specialist in Vauxhall, London
Old 02-13-2010, 09:49 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Or you could just be a rebel and skip the front plate
Welcome to the board! I'll have to give this fix a go in the spring.
Nice looking car!
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 02-13-2010, 06:07 PM
Yeah, removing the front plate isn't an option we've got. How would those forward facing speed cameras pick you up!
Old 02-14-2010, 05:06 AM
Catamax944's Avatar
Would you miss getting speed tickets? That's how i roll for the last 2 years,no problems whatsoever,and no speed tickets. I really like how it looks without it even if i have the proper location where to mount it I first kept it on the dashboard and when i got tired of all the rattling i thrown it in the boot. PS:Welcome to Pelican
Catalin
'86 DD
Old 02-14-2010, 06:27 AM
I'd love to be able to do that! But the UK is super tough on numberplates - you even get pulled over and fined if the numbers or letters are spaced wrong (which some people do to make the plate spell something) or even are written in the wrong font.
But at least the front and rear are designed for the long Euro rectangular plate - even if we Britishers suffered with initial right-hand-drive penny pinching like no switchover for the front and rear wipers and the bonnet release.
Old 02-15-2010, 03:20 AM
