![]() Even more confused...
1983 Porsche 944 Last edited by SpidrVII; 04-19-2010 at 02:08 PM.. |
took the best pic i could, but you should get the idea of where the starter wires go. should have 3 of them in total, 4 if your ground is split
1983 944 Guards Red (87' Implant Complete) |
Starter Wire Connector in Engine Bay
Hello and Thanks again for replying...and crawling under the car to take the pic. But the starter connector wire I'm talking about is in the engine compartment. It's on the firewall and in front of the heater core/blower. Your thumb is touching the wire in your picture and my index finger is pointing to mine. I know where it leads to, but I don't know where it's coming from. The starter wire connector is a green wire encased in a yelllow piece of plastic which slips into a black rubber casing. The green wire leads to the starter, but I need to know where the black rubber casing section connects.
![]() ![]() The good news is that I believe I figured out the vacuum lines and the starter wire connector can be replaced with a straight wire. The black rubber boot/yellow casing is simply a quick disconnect. Thanks again, Mike
1983 Porsche 944 Last edited by SpidrVII; 04-21-2010 at 08:01 AM.. |
ah, the large bare wire your touching is a engine ground, it connects to the firewall just under all the wires there should be a threaded bolt sticking out. the red wire that goes to green that seems to be broken in your picture goes to the O2 sensor on mine.
![]() Thanks so much. We're so close to getting this running that I'm giddy with excitement. Nine months is way too long of time not to be driving this fine piece of German engineering!
1983 Porsche 944 |
black to green sorry, was 4am here and was a bit tired lookin at the pic. same connection though that goes to the O2 sensor, mine has 2 white and one black, though its a newer sensor. those 6 brown wires that join into the eyelet conections also connect to the ground point on the rear of the engine with the larger single ground. also keep in mind for further electrical issues on your car, All brown wires are a ground.
was originally used for the O2, if you ran new wires with your new O2 then its just there. i spliced my new one into it to keep the wiring to the dme the same.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Eureeka
1983 Porsche 944 |
