Not accurate, Acura-te
Send a message via MSN to Mr.Acura-te
Porsche Crest Wondering how to do this?
Hi all later tonight I will post a little more about myself.
I am restoring a '84 944 and I am having a little trouble figuring out how to remove the Porsche Crest from the nose panel. I have been searching for a good solution most of today but I haven't seemed to have had any luck.
I have been using the Tech Info on this website with some of the things on the car so far and would just like to let you all know how wonderful that has been in helping me with different things.
Thanks,
Ron
Old 08-05-2010, 01:43 PM
mistertate's Avatar
stick your fingernails under it and pull it off
dude
Old 08-05-2010, 02:39 PM
Over 40 victim of fate
stogie25's Avatar
Clark's Garage has a write up for that.
http://www.clarks-garage.com/pdf-manual/body-13.pdf
black 1988 Porsche 944 (30 years old and getting younger every day)
black 1997 Jeep Wrangler (very modified)
I didn't know cars came in other colors
Semper Fi
Old 08-05-2010, 02:42 PM
Back from Beyond
Failing Clark's, just ask any teenager - they steal these at an alarming rate.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-05-2010, 03:16 PM
Thank you sir, can't believe I missed that. Really was hoping not to have to take off the nose panel. I really feel like it wouldnt be too bad of an idea to just pry it out and re attach it with some 3M tape.
Old 08-05-2010, 03:21 PM
Sorry to double post but. It was relatively easy to remove the crest.
Good thing my other 944 parts car has a crest that is in way better shape.
Old 08-05-2010, 04:47 PM
gmorken's Avatar
Thanks,
Ron
I found by removing the front bumper (2 bolts), there was plenty of room for my hand to go behind the nose panel and remove the nuts holding the crest on. Much easier than trying to remove the nose panel... added benefit is I got to detail the bumper components on the workbench (still early in our restoration so removal worked out perfect)... .
1985/2 944 Alpine White, Fuchs
Musik Stadt chapter of PCA
Old 08-05-2010, 06:33 PM
Did you miss my previous post? All you need is a painters multi-tool aka 5-Way and you can just pop that sucker right out of there.
Old 08-05-2010, 06:52 PM
Yup, they are easy to get off.. but installing the new one? do the blind nuts stay in place? The early header panel is spot welded, not removable.. There is a small through hole in the internal air channeling "sheetmetal" below the header panel, they somehow fit a tool in there for installing the porsche crest, it's a very tight fit. I don't think you can get at it if the stock radiator plastic ductwork is in place. After looking through a few other posts on the subject, it looks like there are just plastic inserts in the header panel that captivate the badge by friction... no need for tools.
"porsche it's an institution"
Old 08-05-2010, 09:11 PM
Yeah and if you would want added safety just put some 3M double stick on the back of it and it isn't going anywhere.
Old 08-05-2010, 09:55 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
When you reinstall the badge, use a blow dryer to CAREFULLY heat the rubber gasket, then put the gasket on the badge. It's a bit tricky, but if you heat the gasket, it will lay correctly when installed (no edges rolled under).
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 08-05-2010, 10:53 PM
Thanks for the tip sir. Could someone point me into the right direction to post up pictures of my restoration?
Old 08-05-2010, 11:00 PM
When you click on the button "post reply" or "go advanced" next to the quick reply box, there should be an option to attach an image or two.
Originally Posted by pelican advanced reply
Attach a Photo
You may attach a photo of nearly any size - we will resize it for you.
Click here to Upload a Photo... (Valid file extensions: .gif .jpg)
Best to keep the pixel dimentions 800x600/150KB in size or less, larger files get processed "smaller" and sometimes loose quality.
Old 08-06-2010, 12:35 AM
