Water_cooled's Avatar
How to tell if I have an updated H2o pump?
Hey everyone, I've got an 83 944 and I'm going to replace the timing and balance shaft belts. While I'm in there I'm also going to replace the rollers and gears. Are there any tell tale signs for me to look for to determine whether or not my water pump is new because that dictates the size of timing roller I need? Also, posted a picture of the car because I can't figure out how to do it in My Garage.
Old 01-16-2012, 06:26 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
To be able to tell any thing about the Water Pump you first have to remove the Timing Belts Cover to inspect it. The later style pump will have a belt guide rail attached to the water pump along with the larger Timing belt roller (46mm instead of the smaller/older 32mm).
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 01-16-2012, 07:32 PM
Much appreciated! I have the covers removed, seeing both of your indicators. Just trying to make sure that I was on the right track!
Old 01-16-2012, 07:40 PM
if pump has a belt guard, it's updated.
Old 01-16-2012, 07:45 PM
ernie9944's Avatar
This migth help.
Update WP kit
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-16-2012, 07:56 PM
