AFM #725
Gawernator's Avatar
Where to find this device
http://www.928motorsports.com/parts/images/transmission/OilPump1.jpg
I was thinking I should change my transmission oil in a bit to MT-90, not sure what is in there right now. It was an extreme pain on my 83 because I had to make some makeshift tube device that barely worked and took a while, was a PITA, and the jerry rig is long gone by now. Also, is there a difference between the transmission and differential fluid?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 09-26-2012, 07:34 PM
Incorrigible
ditch68's Avatar
Hmm. That one in the link looks homemade from an industrial soap gallon jug pump...
I just remove both drain plugs, drain, put the lower one back in, and fill up with the gear oil bottles. I have one cap I cut off at the right length and stuck a clear tube into, then just tip the bottle and squeeeeeeze it in there.
Jeff
1988 951 all track modded and angry, 2002 Boxster
'88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone.
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field.
Old 09-26-2012, 07:38 PM
Just an important reminder which has been posted here previously - always loosen the fill plug BEFORE you loosen the drain plug.
Reason - these fluids don't get usually get changed that often and the last thing you want is to drain the fluid only to find that you can't get the fill plug out...
As for the filling technique I just use a lrge squeezy bottle with a couple of metres of clear tube so you can thread the tube all way from outside the wheel arch over the tyre under the body and ito the trans - has worked for me twice
Old 09-26-2012, 08:50 PM
AFM #725
Gawernator's Avatar
I definitely made sure to follow that advice. The PO mentioned in passing MT-90 but I don't trust him that much, was a guy in his early 20's. I used a tube with some pipe that flowed over the arch to the tube and was really slow and painful, lol. My shifting is pretty nice right now, only rarely a bit tough into second, rarely, and only when cold generally. MT-90 might not even make a difference, since it shifts nice. I'm curious about the differential, does that use the same fluid? I have to be honest I'm not very sure how it all works together, besides skimming Wikipedia.
Old 09-26-2012, 08:54 PM
ernie9944's Avatar
Et voila!!!! will save a lot of headach when changing your tranny oil.Personally I always use a garage hoist, for the cost it don't worth crawling under the car.Diff & tranny use the same oil,one filer plug for both.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 09-27-2012, 03:51 PM
AFM #725
Gawernator's Avatar
Wish I had a hoist, lol.
Old 09-27-2012, 03:57 PM
Proprietoristicly Refined
John_AZ's Avatar
Harbor Freight has a cheap one on sale for $3.99 with coupon:
Multi-Use Transfer Pump
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 09-27-2012, 04:22 PM
AFM #725
Gawernator's Avatar
John is the man! What coupon are you referring to?
Old 09-27-2012, 04:30 PM
John_AZ's Avatar
Sundays paper.
HF usually puts coupons in with all the other loose coupons for shampoo, drugs, soap. Another in the Sunday movie/food/celebrity magazine. and a third --4 full size newsprint pages of coupons with the other store fliers.
OH, there are about 7 HF in Phoenix, maybe thats why.
John
Old 09-27-2012, 04:36 PM
AFM #725
Gawernator's Avatar
I think I get those in Motor Trend Magazines, thanks
Old 09-27-2012, 04:38 PM
Andrew Gawers' Dad
CHICKS's Avatar
That HF unit is junk. The hoses are even kinked in the pics....Get a funnel, and some hose that fits on the end. Put the other end into the tranny fill hole. Bring the funnel up to the fender, and tape the fuch out of it with blue painters tape. Fill transmission. It's that easy.
Old 09-27-2012, 04:45 PM
Andrew Gawers' Dad
CHICKS's Avatar
They went a bit crazy with it, the tape will hold just fine, but you get the idea.
Old 09-27-2012, 04:49 PM
Andrew Gawers' Dad
CHICKS's Avatar
Or.... Juice jug transmission oil pump
Old 09-27-2012, 04:52 PM
AFM #725
Gawernator's Avatar
Good idea. Thanks also
Old 09-27-2012, 04:55 PM
Toofah King Bad
Rasta Monsta's Avatar
Kudos to the guy who says the pump is junk and then builds a cinder block tower two inches from his fender.
Fully awesome.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-27-2012, 05:06 PM
Andrew Gawers' Dad
CHICKS's Avatar
Fully awesome.
Mmmk. First, the pump is junk. Tried using it to do the fluids on my dads Pinz 710. Might be because it's: $3, made in china, and sold by HF. Second, those are not my pics, just pics from a google search. I suggested the tape, not the blocks. I'll quit feeding the troll now...
Old 09-27-2012, 05:25 PM
alan6272's Avatar
the very first pump shown is the same set up for pumping oil into an out drive lower unit on boats. walmart has them and are cheap. I have one and used it many times, gear oil for out drives is the same weight as for the porsche trans.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 09-27-2012, 06:49 PM
AFM #725
Gawernator's Avatar
I knew that, because CHICK's 944 is red like mine
Old 09-27-2012, 06:55 PM
Custom User Title
mikepellegrini's Avatar
+1 on the ladder and tube - but I put my funnel about hip level, and it works just fine. You need to take the wheel off - makes it easier to route the tubing. I also use clear tubing so you can see the progress.
Very easy job. To drain and re-fill, maybe 30 minutes.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 09-27-2012, 07:05 PM
AFM #725
Gawernator's Avatar
Clear tube, good idea. Mine was clear but pretty corroded and stained lol. Seems like a new funnel and tube is in order... and a trip to Home Depot
Old 09-27-2012, 07:26 PM
