AFM #725
Where to find this device
http://www.928motorsports.com/parts/images/transmission/OilPump1.jpg
I was thinking I should change my transmission oil in a bit to MT-90, not sure what is in there right now. It was an extreme pain on my 83 because I had to make some makeshift tube device that barely worked and took a while, was a PITA, and the jerry rig is long gone by now. Also, is there a difference between the transmission and differential fluid?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Incorrigible
Hmm. That one in the link looks homemade from an industrial soap gallon jug pump...
I just remove both drain plugs, drain, put the lower one back in, and fill up with the gear oil bottles. I have one cap I cut off at the right length and stuck a clear tube into, then just tip the bottle and squeeeeeeze it in there. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
Just an important reminder which has been posted here previously - always loosen the fill plug BEFORE you loosen the drain plug.
Reason - these fluids don't get usually get changed that often and the last thing you want is to drain the fluid only to find that you can't get the fill plug out... As for the filling technique I just use a lrge squeezy bottle with a couple of metres of clear tube so you can thread the tube all way from outside the wheel arch over the tyre under the body and ito the trans - has worked for me twice |
AFM #725
I definitely made sure to follow that advice.
The PO mentioned in passing MT-90 but I don't trust him that much, was a guy in his early 20's. I used a tube with some pipe that flowed over the arch to the tube and was really slow and painful, lol. My shifting is pretty nice right now, only rarely a bit tough into second, rarely, and only when cold generally. MT-90 might not even make a difference, since it shifts nice. I'm curious about the differential, does that use the same fluid? I have to be honest I'm not very sure how it all works together, besides skimming Wikipedia.
Et voila!!!! will save a lot of headach when changing your tranny oil.Personally I always use a garage hoist, for the cost it don't worth crawling under the car.Diff & tranny use the same oil,one filer plug for both.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
AFM #725
Wish I had a hoist, lol.
Proprietoristicly Refined
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
AFM #725
John is the man! What coupon are you referring to?
Sundays paper.
HF usually puts coupons in with all the other loose coupons for shampoo, drugs, soap. Another in the Sunday movie/food/celebrity magazine. and a third --4 full size newsprint pages of coupons with the other store fliers. OH, there are about 7 HF in Phoenix, maybe thats why. John
AFM #725
I think I get those in Motor Trend Magazines, thanks
Andrew Gawers' Dad
That HF unit is junk. The hoses are even kinked in the pics....Get a funnel, and some hose that fits on the end. Put the other end into the tranny fill hole. Bring the funnel up to the fender, and tape the fuch out of it with blue painters tape. Fill transmission. It's that easy.
Andrew Gawers' Dad
![]() ![]() They went a bit crazy with it, the tape will hold just fine, but you get the idea. |
Andrew Gawers' Dad
AFM #725
Good idea. Thanks also
Toofah King Bad
Kudos to the guy who says the pump is junk and then builds a cinder block tower two inches from his fender.
Fully awesome.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Andrew Gawers' Dad
Mmmk. First, the pump is junk. Tried using it to do the fluids on my dads Pinz 710. Might be because it's: $3, made in china, and sold by HF. Second, those are not my pics, just pics from a google search. I suggested the tape, not the blocks. I'll quit feeding the troll now...
the very first pump shown is the same set up for pumping oil into an out drive lower unit on boats. walmart has them and are cheap. I have one and used it many times, gear oil for out drives is the same weight as for the porsche trans.
1983 944 ,1983 V-65 magna catalina22 sold baja ski boat sold my toys |
AFM #725
I knew that, because CHICK's 944 is red like mine
Custom User Title
+1 on the ladder and tube - but I put my funnel about hip level, and it works just fine. You need to take the wheel off - makes it easier to route the tubing. I also use clear tubing so you can see the progress.
Very easy job. To drain and re-fill, maybe 30 minutes.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
AFM #725
Clear tube, good idea. Mine was clear but pretty corroded and stained lol. Seems like a new funnel and tube is in order... and a trip to Home Depot
