AFM #725
Gawernator's Avatar
Chasing down a hard start
Okay, so my 944 has never /not/ started. (double negative) However, it always has to some extent taken awhile to start. On Ideola's garage I saw a video of the stock starter taking 1.5 seconds to start. I know it's not like a brand new car, starting almost immediately. But my 944 can take 2-3.5 seconds to start up, even four seconds. The thing is, it's not always. Sometimes it starts up in a second, sometimes it turns over multiple times before firing. I used to think it was worn electrical components, or some other issue, but I have replaced so much on the car I'm running out of ideas. The only things in the engine bay that aren't new (to my knowledge) The ignition coil, starter (right) and there's my alternate theory that something is wrong with the fuel pressure regulator, leaving voids in the fuel rail and that's why it takes longer to start?
Dist cap/plugs/wires all new no vacuum leaks (all new hoses/seals) new fuel hoses, fuel pump, fuel filter has maybe 10,000 miles or so on it. Air filter is clean K&N. Changing brand of gasoline wasn't it either, lol. Guesses?
Edit: Oh, Injectors are all rebuilt/ with new seals as well
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-04-2013, 12:19 AM
Proprietoristicly Refined
John_AZ's Avatar
Gawer,
Because you said it is intermittent, and you have put in new NGK plugs and have newer plug wires:
If your battery is newer...
If your charging system is keeping the battery fully charged....
If you do not have abnormal drain on the battery overnight---Clarks says normal drain from the radio and alarm is up to 45ma----(my drain is about 10ma with only radio presets)
...and I know you have cleaned all the main battery cable ends...
When you get into the car to start ------do not touch the gas pedal--just turn the key
If the car fires up "normally" without the longer delay you may just have a typical 944.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 05-04-2013, 04:15 AM
porschetub's Avatar
My car is the best car for starting ever and i've owned a few even with a low battery it cranks slow and starts straight up.
The only time I remember a non start was a dead fuel pump relay,swapped out for my spare and it fired in seconds.
Have you got good voltage @ your new fuel pump?,don't think it would be a FPR issue,not a very common fault.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-06-2013, 07:04 AM
AFM #725
Gawernator's Avatar
Haven't checked voltage but I don't have problems with it actually starting. Started pretty quickly today but I notice it seems like it turns over, then there's almost like a pause as it starts up in a slow way then boom fully running. Weird...
Old 05-06-2013, 08:31 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Have you considered the check valve in the fuel pump? If it's defective, all the fuel drains out of the fuel lines when the car sits and takes a while for the fuel to get to the injectors.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 05-09-2013, 01:22 PM
