CV boot clamp tool
I take it that I need an Oetiker type pincer pliers to affix the crimp clamp to the CV boot?
Will such a tool work for small clamps like on the brake fluid reservoir?
Can I just dull down the teeth on a pair of those snips for cutting nails flush with a deck?
Old 01-29-2014, 04:31 PM
for the smaller clamps the constant tension hose clamp may be better. as the hose dries out and shrinks the hose clamp self tightens
Spring Hose Clamps | eBay
Old 01-29-2014, 04:36 PM
I just got the 10 dollar Loebro kit in my hands, and a pinch-type clamp for the CV boot. This is in fact an Oetiker type tounge-in-groove pinch clamp.
does a 944 actually need this pinch clamp? the PET doesn't show as such.
if it does, then there are the special pliers that are required for this and other cars like GM's:
Pelican Parts.com - CV Boot Clamp Pliers for Earless-Type Clamps
I'll report back once I actually get to look under my car (it might as well be in another country right now).
87 944 NA
Old 01-30-2014, 06:17 AM
On those band clamps with the "ears," that is what I use... a pair of end nipper pliers similar to Harbor Freight #38496.
'86 944 N/A
Metallic graphite
Old 01-30-2014, 04:39 PM
Bah, clamp, who needs it. I use zip ties
Old 01-31-2014, 04:52 AM
Toofah King Bad
Rasta Monsta's Avatar
Last one of these I did the boot was so freakin' tight it barely installed. Tossed the clamps.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 01-31-2014, 08:09 AM
