front main seal doubt
Put on new front main seal but when done I got worried the lip flipped in on itself, paranoia?
'87 924s resurrection project; '83 944 engine
Hudsonville, Michigan
Old 06-23-2017, 08:56 PM
I would think that's normal. Still should seal properly.
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 06-24-2017, 03:47 AM
Seals have ribs or flutes to move the oil back into the motor with the direction of rotation. I would install it the right way.
Old 06-24-2017, 05:53 AM
Back from Beyond
Just withdraw the oil pump drive sleeve and reinstall. Should work to push that seal lip back in.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 06-24-2017, 11:19 AM
Be sure the tensioning spring is still in its proper location. It probably won't be pretty if it goes through the oil pump.
Old 06-24-2017, 12:46 PM
I used an OE seal there just recently and it did not sit flush into the housing. It stuck out about as much as the one you show and doesn't leak.
Old 06-25-2017, 09:06 PM
