front main seal doubt
Put on new front main seal but when done I got worried the lip flipped in on itself, paranoia?
'87 924s resurrection project; '83 944 engine Hudsonville, Michigan |
I would think that's normal. Still should seal properly.
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
Seals have ribs or flutes to move the oil back into the motor with the direction of rotation. I would install it the right way.
Back from Beyond
Just withdraw the oil pump drive sleeve and reinstall. Should work to push that seal lip back in.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Be sure the tensioning spring is still in its proper location. It probably won't be pretty if it goes through the oil pump.
I used an OE seal there just recently and it did not sit flush into the housing. It stuck out about as much as the one you show and doesn't leak.
