1979 928 V8 automatic
New to the 928, had a 1970 911 Targa for years but off it went and I'm looking at getting back into vintage Porsche again.
I'm looking at a very original 1979 V8 automatic. The seller has advised there is a fuel pressure issue, the engine turns over and fires with starter fluid but not on it's own.
Any ideas what this might be and if its a sign of bigger issues?
Any general advice about the fuel pressure would be appreciated, and experiences with the 928. Good and not so good!
Old 03-27-2025, 02:45 AM
harborman's Avatar
Well, if it's a fuel pressure issue, check out the fuel system ! Pump, filter, etc.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 03-27-2025, 09:41 AM
Thanks, yes that would obviously be a starting point. I was wondering if anyone has experienced this and it turned out to be a bigger issue. I don't have the car yet so seeking some advice before/if I purchase.
Old 03-28-2025, 02:28 AM
Linderpat's Avatar
It could be as simple as a fuel pump relay gone bad (always do the cheap easy stuff first) or a fuel pressure regulator gone bad. The FPR has a diaphram in it, which over time wears out. Not a hard job for a DIY, but getting the correct part is critical. If the car starts, that's a good sign.
I do recommend jumping to the Rennlist 928 forum and reading the FAQ sticky thread at the top of the forum all the way through, before you buy the 928. It will answer all of your initial questions and tell you what to look out for. Good luck, these are great cars.
Ed
85 928 5 spd (guards red over tan)
07 Shelby GT500 6 spd (torch red over two tone black and red leather)
Old 03-28-2025, 07:43 AM
Thank Linderpat. I bought it, there were too many good things with the car not to. I'll figure it out, sometimes you have to take a risk with classic cars!! I did with the 1970 911 I had and it paid off in many ways. I had a look over the common questions and things to look out for with 928's. Looking forward to the journey!!
Old 03-29-2025, 03:04 AM
