928-Electrics Guy
Alan
1994 928 GTS Black/Black Manual |
Maybe I am on crack. I will shoot a quick vid of the flex. I'm afraid to go tighter and start damaging bearings.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Spoke to the seller and he has a 120 amp that I can trade out with (pay difference). I'm gonna go with this. Will post more readings when i get the 120 amp installed.
Hello all! Sorry I haven't posted more on this topic when i put in my 120 Amp alternator in. I still get light dimming and I can see my volt drop to under 10 in my stock Volt Gauge upon low rpm's. I did all the 14 pin and Post cleanup and still the same. I am really kicking myself for not just doing the Delco Swap in the first place.
When I was cleaning the 14 Pin, I did notice the wire that goes to the Alternator (exciter?) and it had a little greenish tinge to it. Would it make a difference if I just ran another wire straight from the 14 Pin to my Alternator?
928-Electrics Guy
No - your alternator is starting up OK. I think you just have belt slip at idle.
Alternator belts need to be super tight. Take it to a shop - they will know how tight to crank it. Alan
Thanks Alan for the reply. I will try and tighten it up again. Is there some sort of way to gauge the proper tightness?
According to the shop manual, the belts should (flex) give 10mm at center between pulleys.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
1985 944 |
928-Electrics Guy
BTW if it has been slipping for a while the belt will be in poor shape - the inside surface will get glazed from the friction and will slip more than a new belt would.. You may be able to feel this... It will be getting hot at idle also.
Alan
Thanks Jim and Alan. I will first check the belt and get it to specs. Also, will check the belt condition. If all those fail, it's Delco swap time. Much appreciated for the info.
I have the EXACT same symptoms in my 82, along with an intermittent tach and bouncy oil pressure needle.
I'm wondering if my light dimmer switch under the dash on the left has high resistance in it? I'll bet it does. Dimmer switches never last. Maybe I'll over-ride it because the lighting is so weak anyway.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
Have you already over-ridden your dimmer switch? Is it a huge pain in the butt to remove the pod?
Yes, I don't use my dimmer. The wires are plugged together. Here's a link to a lot of pics when I changed out my PCB and put some reflective foil to reflect the lights better. http://porsche928forums.com/viewtopic.php?f=9&t=4&st=0&sk=t&sd=a&start=520
Awesome. Thanks.
Great Pics
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
FYI, tightened my belt last night and same issue this morning. Looks like Delco Swap out. I plan to do some stuff that will require more electrical power so I can't have this. More to come.
I want one of those high output alts, too. Where from?
eBay is where I got mine. Obviously not working very well. Why would you follow my grief. My suggestion is don't do it, unless you want to buy mine
I'm going to Delco Swap it.
Delco is the company that builds electronics for General Motors. You can go to any auto parts store (with your Bosh Alt.) and tell them you want a chev alt with the same mounting placement in 100 amps or more. they will more then likely sell you a standard 110 amp alt.
I was going to rebuild my bosh but now that i see this thread I will do the swap to the chev Alt. I have done this to many fords and implement equipment before. They are a good replacement.
