Pulling engine, 1 question?
Pulling engine out of my 86.5
Taking my time.
Why do they want you to remove the two transmission mount bolts at the rear of the car?
Am I looking at it wrong? Or is there a reason?
Old 12-09-2009, 04:56 PM
Petie3rd
Mrmerlin's Avatar
possibly to push the trans / front bell housing back a bit to aid in pulling the engine out /off of the motor mounts. Is this a 5 speed or an auto??
5sp needs the clutch pack removed first.
auto needs the flex plate disconnected, mark it to the flywheel
Old 12-09-2009, 05:35 PM
Arizona_928's Avatar
makes sense. you need acouple inches, to clear the clutch ass. and to get the bell housing cleared.
dolor et pavor
Copyright
Old 12-09-2009, 05:42 PM
Automatic transmission.
86.5 Porsche 928, 75 Porsche 914, 2.0, 2001 Boxster.
Old 12-10-2009, 03:01 AM
Loosening those bolts will save the trans mounts from being contorted and allow the parts to move easier for alignment.
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 12-10-2009, 05:42 AM
What about lifting eyes? There are none on the motor, are these just your normal homemade angle iron eyes?
Old 12-10-2009, 11:16 AM
There's an eye at the right front and left rear of the engine. Are you sure they're not there?
Mike S.
Old 12-10-2009, 01:59 PM
Please, can someone tell me where the lifting eyes attach to the engine on an 85 - 86 928? I do not see any on mine and I am ready to extract. I do not want to get it too far off the Center of Gravity.
Picture would be nice.
Old 12-13-2009, 04:30 PM
MPDano's Avatar
I can't answer for a 32V, but a 16V has two. One on each front and rear corner, can't remember exactly which corner. They are so off balance that even an engine tilt device wont get it even. I had to use a strap to the front pulley to balance the engine.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-13-2009, 05:06 PM
Petie3rd
Mrmerlin's Avatar
lifting hooks for the engine aare at the right front corner and the left rear corner.
I hope they are still attached
Old 12-14-2009, 10:45 AM
MPDano's Avatar
Fred, if they are not there, just get a hold of 928 Intl and buy a couple of used ones (50% off) for a few more days.
Old 12-14-2009, 10:51 AM
Made my own, step 1 complete, now what???? Valves.
Found, cracked flex plate, bolts missing everywhere, lots of shabby work previously performed.
Old 12-14-2009, 04:11 PM
Network Native
Danglerb's Avatar
Congrats on your outing.
Old 12-14-2009, 06:48 PM
Petie3rd
Mrmerlin's Avatar
I would suggest that you tape a towel folded over to the top of each fender use blue tape this prevents most scratches from the work your doing the red cover will fit neatly along the front of the bumper cover to protect that as well
Old 12-15-2009, 06:47 AM
Network Native
Danglerb's Avatar
Roger from time to time does a deal on the real Colgan set, well worth the money.
Old 12-15-2009, 11:51 AM
80 928
God only knows what greasy wrench jockey was allowed to work on your beloved shark
Old 12-15-2009, 02:47 PM
Yikes! The engine was pulled with the radiator still mounted! I can't watch.
1982 928 S Euro 5 speed
Old 12-15-2009, 03:15 PM
MPDano's Avatar
Looks like the Condenser to me. Radiator would have Side Tanks.
Old 12-15-2009, 03:19 PM
Network Native
Danglerb's Avatar
Cracked flex plate, I wonder what iceberg that could be the tip of?
In the long run, I think its best to tear everything completely apart and put it back together renewing as needed.
Old 12-15-2009, 03:20 PM
naa, I think that's the air condenser.
dolor et pavor
Copyright
Old 12-15-2009, 04:26 PM
