Help identifying a Caliper
Hi guys,
My 911 came with a 928/930 brake set up. If you guys wouldn't mind helping me identify what year this calpier/rotor combo came off of I'd appreciate it. I need to replace the front pads and would like to rebuild the calipers so it'd be very helpful to know what years they were on. Thanks! Amir
that911.tumblr.com |
That looks like an 928 S4 Caliper. Just take the part number off it and punch it in Pelicans Part search. It should come up with a year range.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
That looks to be standard 928s4 parts and came on 1986.5 and up. These are 4 piston and have all the power you will need. I cant imagine how fast they would stop a lighter car.
![]() Not a good picture but you get the idea.
Warning - I play with Porsche's ![]() 1970 -914 / 1982 -911 1984 -928 / 1987 -928 |
Thanks guys!
The car definitely stops pretty well now, but with no Power assist and 2300lbs I have a lot of trouble getting a good bite out of the Pagid Oranges in there since it's tough to get heat. I'm going to switch a carbotech front rear set up, rebuild my calipers, and enjoy my excellent stopping!
The early S4 and later S4 calipers have different size pistons by a couple mm. There are no outward visual clues to tell the difference. Unless there is a part # on the caliper, you my just have to pull the pistons and measure them to insure correct new seals. BTW. to install those on a 928 we would have to flip them over and change the plumbing (mounted on the trailing side of our rotors)
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold) Neon SRT4 track car |
The issue may not be the pad. I have early S4 calipers on my 928 with stock pads. They too seem to lack intitial bite. They will stop great but the caliper feels like its slow to react. On the other hand I have Big Reds on my 951 with Pagid orange. They have crazy initial bite even cold. Almost too much, it takes a lot of practice and a real precise foot to manage it
Once again everyone has been a great help! Thank you guys.
