Engineer of profanity
924CarreraGTP's Avatar
I fabricated a kill switch for my 928
Do you guys like my kill switch? Let me know your thoughts. This even conforms to the proper battery disconnection procedure. The only thing that doesn't completely satisfy me is that the secondary gound cable from the switch to the body is not copper. However, this system works great and has been 100% reliable for the past two three weeks. I thought I would share this.
1970 Porsche 911T Black
1990 Porsche 944 S2 Red on cashmere
1984 Porsche 928S Euro ROW GP white on black
Old 02-01-2012, 11:26 AM
928 Newbie
dcrasta's Avatar
Cant tell from the picture but is that wire sufficient ? Looks a little thin, but good idea..
Old 02-01-2012, 11:36 AM
Pete R's Avatar
but why?
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 02-01-2012, 11:46 AM
MPDano's Avatar
Originally Posted by Pete R View Post
but why?
I think because the ground cable should be a lot thicker (lower number Gauge). Your Ground cable looks about what I use on my Stereo amps.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-01-2012, 12:12 PM
A switch between the relay and the fuel pump is easier,smaller switch can be hidden anywhere close to the drivers seat. I use a gravity cut off switch from a bosch injection system , auto shut off if the car is in accident (or flips)
The reset button doubles as a security off switch.
Old 02-01-2012, 01:39 PM
Architecture & Porsche's
ha ha, bought the switch yesterday, was gonna do the exact same thing tomorrow night. Funny.
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 02-01-2012, 01:58 PM
MPDano's Avatar
I still think it's a "Great" idea, but I personally would go with a larger gauge cable. We all know the ground issues we have on our 928's so why skimp on the ground that comes "directly" off the battery? It's the Main Bad Boy
Old 02-01-2012, 02:24 PM
Would it not be better to mount a kill switch where it can be reached by a seated driver? Unless you just want an easier way to disconnect the battery for when the car is sitting.
1986 Porsche 928S
2011 Ford F-150 Platinum EB
Old 02-01-2012, 04:32 PM
Pete R's Avatar
lol, my bad, why the kill switch?
but your right, the cable is (appears) too small. He'll know if it starts smoking.
Neon SRT4 track car
Old 02-01-2012, 05:21 PM
Network Native
Danglerb's Avatar
I was thinking the kill switch needed to be on the outside?
Old 02-01-2012, 06:00 PM
19psi's Avatar
but why?
It would be a quick convenient way to cut power during maintenance but other than that I'm not sure.
George in Indiana
928 Weissach #153
Cayenne S
Old 02-01-2012, 06:07 PM
MPDano's Avatar
Great Anti-Theft Device
Old 02-01-2012, 06:56 PM
Who wants to steal a 928? Why would someone want to steal something that will cost them money?
Old 02-01-2012, 07:50 PM
Pete R's Avatar
It's not worth resetting the radio and clock to use as a theft device, it's out of reach of the driver for any safety benefit, and if it's for maintence, how much is being done? It's not that hard to just unscrew the ground to begin with. While it's kinda neat I don't see any real purpose for it.
Neon SRT4 track car
Old 02-02-2012, 04:11 AM
Luis_M's Avatar
I had the same switch in my car for a while between the battery ground and the chassis, since I wasn't driving the car much and didn't want to run down the battery between uses. I put the switch in around 2007 and loved it while it lasted. But.... the switch failed this fall. Since it is sealed, no way to clean it so I had to replace it. Ironic that the "newest" electrical part on the car failed. No telling how long it was making lousy contact before failing, either.
I replaced it with a knife switch by Wirthco. Much more "reliable" in my opinion. Quite handy now that I'm doing work on the electrical system. Once I'm done, I may retire it, but for now, it's pretty useful.
My current switch is similar to this one and was about $20-25
81 928S Euro 5sp, 03 996TT X50 Tip, 02 Z3M S54 5sp
past favorites: 99 M3 E36 5sp
Old 02-02-2012, 08:03 AM
Network Native
Danglerb's Avatar
When I am "doing stuff" I find it easier to loosen the neg clamp on the battery and take it on and off instead of messing with the wingnut.
Old 02-02-2012, 08:49 AM
MPDano's Avatar
Same here, my wingnut is tightened with channel locks and left alone.
these are the only type of Battery Disconnects I would trust since they are made by a company that makes proven race car stuff.
The boots to cover the connect part.
Here's a quote of the cable gauge sizes:
Meets sanctioning body requirement that terminals on the master electrical cut-off switch be covered
Perfect compliment to Moroso Part Nos. 74100, 74101, 74102 and 74106
Prevents the shorting out of exposed terminals
When installed, creates a finished “clean look” to disconnect switch wiring
Constructed out of high quality, pliable, race environment friendly rubber
Accommodate 2 to 4 gauge wire and 1/2" to 3/8" terminal studs
Can be installed before or after termination of remote fitting ends
Two boots per package; one each Black/Red
Link to Morosso Battery Disconnects.
Moroso : Category Display
Old 02-02-2012, 10:34 AM
Pete R's Avatar
I replaced my negative cable wingnut with a washer and allen bolt. I leave the allen right there in the tool area. I have to secure a couple large amp cables as well as the battery cable to it works for me
Neon SRT4 track car
Old 02-02-2012, 10:52 AM
Actually my car has draw thats dropping the battery. Big Surprise huh? Only, I've pulled tested the fuses and cannot isolate it. So this is what I did. I plan to get another stock ground strap and connect it to the body in a day or two. I agree that it's not a perfect set up yet.
Old 02-02-2012, 01:37 PM
MPDano's Avatar
Aren't those fun. I remember my Brother fixing my electrical short in my 79 Seville back in the day. I remember him using a $2 tester light and he fixed it in 5 minutes. I probably should have been paying attention when he fixed it too. Automotive Electrical Troubleshooting is a Talent, that's for sure
Old 02-02-2012, 01:45 PM
