82 928 euro atm/lsd
Runs rough with new tbelt ??? Help
Hi everyone its been a while but i finally got her running after my tbelt disaster.I have some issues and need some help
#1 I installed a new tbelt and after sitting over the winter it idles fine but when i get on the gas it boggs down and backfires over 2500 rpm. I checked the timing marks after running the car and everything looks dead on. It had almost no gas in the tank and put 5gal of fresh fuel. By accident i did go to charge the batt and put the charger on the wrong posts while charging the batt. (I know rookie mistake) Im thinking maybe a fuel issue, the fuel pump in the back was making a loud buzzing noise louder than normal????.
#2 when removing the locking tool on the flywheel i forgot how the slave cyl goes back in. There's a round piece with a point on the outer end and it looks like a ujoint end cup. sounds silly not to remember but started doing the job last sept and i dont have a garage so i had to wait till summer.
(do i need any special tools to bleed the slave cyl.)
1979 928 5 speed 90k
Old 07-07-2012, 10:21 PM
19psi's Avatar
Idles fine and bogs down immediately when giving it gas is most likely due to a sprocket being just one tooth off.
George in Indiana
928 Weissach #153
Cayenne S
Old 07-07-2012, 10:49 PM
MPDano's Avatar
I agree with George
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-08-2012, 12:43 AM
1982_928's Avatar
What they said
Jonah Boyd
78 928 5 speed - #111
81 928 5 speed - the "Copper Turd"
81 928 Auto
Old 07-08-2012, 06:57 AM
1982 928 us
if you have distributor and bump it .
1982 Porsche 928 us
Old 07-08-2012, 09:27 AM
82 928 euro atm/lsd
I checked the timing and its dead on. i think its fuel issue,the pump makes a buzzing noise while its running and all of a sudden stop making that sound then wants to shut off on me.
when i charged the battery i mistakenly put + to - and tryed to start the car. i checked all the fuses under the dash and all look good.????
Old 07-09-2012, 04:42 PM
928NZ's Avatar
Bogging down with throttle
I had this problem on my 1984 Euro S2 - turned out to be a vacuum line off at the front of the throttle body / plenum.
Old 07-09-2012, 07:53 PM
