Super Moderator
i guess that term isn't universally known?
https://forums.anandtech.com/threads/thatll-buff-right-out-expression-where-does-it-come-from.1469236/ https://www.urbandictionary.com/define.php?term=It%27ll%20Buff%20Out
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Yup got it, wasn't sure who you were addressing it too.
It's like when I broke my arm..."just walk it off" Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Made some progress. Cerakote air dry on rears so far.
![]() Thanks Mike G. Last edited by Mike Goebel; 04-23-2020 at 09:52 AM.. |
I no longer believe there is some sort of unattainable seal between the calipers. Why would there need to be one as the brake fluid gets to the other side via the crossover pipe!! So why would there be any kind of seal between the calipers? I did NOT split my calipers do to fear of ruining this POS seal.
Thanks Mike G. |
Super Moderator
mike, maybe you can provide a 951 brake cerakote service for those with fear?
Just a wild guess, but when you stand on the brake pedal, you're applying a lot of pressure to push the pistons out?
Don't think the 22% takes care of your "incidentals"....
![]() Sox
Good point Total Wine bills are gettin up there!!
Mike G. |
I recently upgraded my braking system. Went from the stock old single piston floating calipers to the turbo setup off the same year (1986). I dismantled the Brembo calipers but did not split them. (no need to). Bead blasted them then washed them. I hit them with a good hi temp primer then a few light coats of VHT caliper paint. After I painted them, I baked them in my oven at 250 degrees for one hour to get the paint nice and hard. when they cooled I sprayed them with VHT clear. I see no color change or peeling after about 1000 miles. Pictures can be see on the NA 944 forum under Mike's rebuild journey! Just my 2 cents
Wished my suspension and rotors looked that clean ....
Sox
![]() And the rear. |
