Splitting M030 front calipers
I've heard a few folks tell me not to split the front calipers but none of them could tell me why. So any info is appreciated.
Thanks Mike G. |
In the Fires of Hell.....
Why do it? It is incredibly hard to do in the first place, and for what benefit?
Clean them and replace the seals/pistons - done.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
See!! still no one can tell me!! hahaha
I'm restoring them!! I'm going to be sandblasting them and all the hardware that holds them together will be removed. Plus they will be ultrasonically cleaning after the blasting. So if the fall apart after any of those processes I will need to put them back together. If they don't I'm fine with not splitting. However if there is a seal between the half's and they are 32 years old might not be a bad idea to replace. Mike G. Last edited by Mike Goebel; 03-18-2020 at 07:52 AM.. |
Super Moderator
can you restore them without splitting them? i think the reasoning is since the brakes are a critical life and death part, if it ain't broke, don't fix it.
i've also heard that as difficult as it is to split the brembo caliper halves, it's pretty much impossible to re-seal them after they're split because the repeated heat cycling creates a unique seal for each caliper. do you want to end up with leaking calipers? i also hope you're not thinking of repainting them. read this: https://www.brembo.com/en/company/news/5-reasons-not-to-use-repainted-brake-calipers-brembo
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Yeah I've read that before. But again no one has any proof of why they can't be resealed. Is there a special secret o-ring? What holds them together after all the bolts have been removed? No one knows. Well I'm sure there must be someone that has done it and can actually comment on why it can or can't or should'be be done.
Mike G. |
Ok I decided to bother my Porsche brake expert, I get one question a year. He said there is no problem with separating and reassembling the calipers, however the issue is with the square edge seal between that is no longer available!!! If that seal gets damaged you're SOL!! But he also said it can be done if you are very very careful. Since I'm more of a brute I'm not going to separate them.
YAY!! Mike G. P.S. I didn't ask him about painting because I don't want to hear his answer. hehe |
I am more of a 'Hog ass' then brute, but end results seem to be similar.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
Super Moderator
there's so many other things on our cars that need actual fixing, i still have to ask why fix something if it ain't broke?
I went to check the brake fluid level and there was about 1/8" of mud mixture in the bottom of the reservoir. Pretty sure they haven't been bled in over 10 years, maybe never. When I removed the pistons from the calipers there was a lot of muck behind all of them. So I figured brakes are pretty important so I might as well rebuild them and flush out the entire system. And of course while you're in there............................................. .$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Mike G. |
Then this happens.
![]() I've decided to Cerakote them in Black. It's pure fun and a learning experience. Mike G. |
Guess it’s not such a bad idea to look at your calipers once in a while.
![]() Found two cracks on the front right caliper. Mike G. |
Abort Abort. This realization was influenced from too much drinking. All is well All is well. It's only a casting defect!!
Mike G. |
Well at least the cracks did not have pink elephants in it
Speaking of cracks, check these out in the hose from the turbo to the inter-cooler hard pipe...
Sox ![]() ![]()
Still looking fresh!!
Mike G. |
Mike I don't understand the words that are coming out of your post..(misquoting the guy in rush hour).
Sox
Super Moderator
that'll buff right out.
Nize you are referring to Mike's brake calipers and not my cracked turbo hose ?
Sox
