Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Splitting M030 front calipers
I've heard a few folks tell me not to split the front calipers but none of them could tell me why. So any info is appreciated.
Mike G.
Old 03-17-2020, 07:09 PM
In the Fires of Hell.....
kdjones2000's Avatar
Why do it? It is incredibly hard to do in the first place, and for what benefit?
Clean them and replace the seals/pistons - done.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-18-2020, 06:44 AM
See!! still no one can tell me!! hahaha
I'm restoring them!! I'm going to be sandblasting them and all the hardware that holds them together will be removed. Plus they will be ultrasonically cleaning after the blasting. So if the fall apart after any of those processes I will need to put them back together. If they don't I'm fine with not splitting. However if there is a seal between the half's and they are 32 years old might not be a bad idea to replace.
Mike G.
Old 03-18-2020, 07:47 AM
Super Moderator
nize's Avatar
can you restore them without splitting them? i think the reasoning is since the brakes are a critical life and death part, if it ain't broke, don't fix it.
i've also heard that as difficult as it is to split the brembo caliper halves, it's pretty much impossible to re-seal them after they're split because the repeated heat cycling creates a unique seal for each caliper. do you want to end up with leaking calipers?
i also hope you're not thinking of repainting them. read this:
https://www.brembo.com/en/company/news/5-reasons-not-to-use-repainted-brake-calipers-brembo
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 03-18-2020, 08:00 AM
Yeah I've read that before. But again no one has any proof of why they can't be resealed. Is there a special secret o-ring? What holds them together after all the bolts have been removed? No one knows. Well I'm sure there must be someone that has done it and can actually comment on why it can or can't or should'be be done.
Mike G.
Old 03-18-2020, 09:52 AM
Ok I decided to bother my Porsche brake expert, I get one question a year. He said there is no problem with separating and reassembling the calipers, however the issue is with the square edge seal between that is no longer available!!! If that seal gets damaged you're SOL!! But he also said it can be done if you are very very careful. Since I'm more of a brute I'm not going to separate them.
YAY!!
Mike G.
P.S. I didn't ask him about painting because I don't want to hear his answer. hehe
Old 03-18-2020, 10:11 AM
soxnail's Avatar
I am more of a 'Hog ass' then brute, but end results seem to be similar.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 03-18-2020, 10:27 AM
Super Moderator
nize's Avatar
there's so many other things on our cars that need actual fixing, i still have to ask why fix something if it ain't broke?
Old 03-19-2020, 01:38 PM
I went to check the brake fluid level and there was about 1/8" of mud mixture in the bottom of the reservoir. Pretty sure they haven't been bled in over 10 years, maybe never. When I removed the pistons from the calipers there was a lot of muck behind all of them. So I figured brakes are pretty important so I might as well rebuild them and flush out the entire system. And of course while you're in there............................................. .$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Mike G.
Old 03-19-2020, 02:02 PM
zmf zmf is offline
How much of that do you think you could remove with just air pressure during a rebuild? It's probably sufficient.
Old 03-29-2020, 04:01 PM
I sometimes wish my mind worked that way. But it just doesn't!
Mike G.
Old 03-29-2020, 05:03 PM
Then this happens.
I've decided to Cerakote them in Black. It's pure fun and a learning experience.
Mike G.
Old 03-29-2020, 06:58 PM
Guess it’s not such a bad idea to look at your calipers once in a while.
Found two cracks on the front right caliper.
Mike G.
Old 04-01-2020, 08:43 PM
Abort Abort. This realization was influenced from too much drinking. All is well All is well. It's only a casting defect!!
Mike G.
Old 04-02-2020, 11:18 AM
soxnail's Avatar
Well at least the cracks did not have pink elephants in it
Old 04-02-2020, 11:23 AM
soxnail's Avatar
Speaking of cracks, check these out in the hose from the turbo to the inter-cooler hard pipe...
Sox
Old 04-03-2020, 08:57 AM
Still looking fresh!!
Mike G.
Old 04-03-2020, 11:18 AM
soxnail's Avatar
Mike I don't understand the words that are coming out of your post..(misquoting the guy in rush hour).
Sox
Old 04-03-2020, 12:14 PM
Super Moderator
nize's Avatar
that'll buff right out.
Old 04-04-2020, 03:15 PM
soxnail's Avatar
Nize you are referring to Mike's brake calipers and not my cracked turbo hose ?
Sox
Old 04-05-2020, 07:15 AM
