Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Post Most psi seen!! a 2.5 block take?
What is the most boost or psi, anyone has seen on a dyno run or boost guage, for a 2.5 liter block either Turbo or modified NA block?
Kevin
PCM Injection
Old 10-12-2001, 07:04 PM
wolfrpi's Avatar
Post
24-25 briefly
Erick
Old 10-12-2001, 08:04 PM
Post
Wolf:
Was that boost or Absolute pressure?
Kevin
PCM Injection
Old 10-12-2001, 08:13 PM
Post
I've seen 20psi boost. 20-24psi absolute would be stock or less so I'm sure that means boost.
'86 951 Graphite Metallic/Tan
Old 10-12-2001, 10:21 PM
adrial's Avatar
Send a message via ICQ to adrial Send a message via AIM to adrial
Post
I know someone in Florida that runs 22psi in a 951...he knows someone that runs 40psi + NOS....
the 22psi car had a O-ringed head and wide fire headgasket...not sure what other engine mods. The 40 psi I have no idea.
Old 10-13-2001, 05:11 AM
dan10101's Avatar
Cool
I've seen 21psi briefly with a stock block 2.5. I usually run 18psi. Currently working through the startup bugs on a new APEXi AVC-R boost controller. So far the most I've been able to get out of it is 17.
Give me another week or 2 and I'll do a writeup on it.
DanD
http://www.Boost-O-Holic.com
Old 10-14-2001, 05:51 AM
Post
Since we are on the boost subject what is an safe boost to run in an 951, that is stock no new gaskets or stuff like that?
Old 10-14-2001, 03:36 PM
951carter's Avatar
Post
you cannot raise the boost w/o chips or the DME will cut you off. With just chips i would advise @ 15 psi. I have run 24 psi before with a wide-fire gasket and a shaved head which raises compression slightly. All internals were stock at the time.
Old 10-17-2001, 05:35 PM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
I hit 28.6lbs (hi boost recorded on my AEM tru-boost), running a k27/6 on a turbo s with stock internals, wastegate stuck closed. Damn happy I didn't send this engine over the rainbow bridge though. But damn, that was one hairy ride for a few seconds.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-28-2012, 03:31 PM
someone here in colorado was running 30+psi on his old 2.5 engine
Old 07-28-2012, 03:53 PM
I ran 20 psi boost briefly with autothority maf, autothority chips, stock fpr and stock injectors and it was fun. I do run 15 psi with a 3 bar regulator and performance chips for everyday driving.
Old 07-29-2012, 10:25 AM
your average wrencher...
also what are you running? 93? 101? 118? E85??
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 07-30-2012, 08:45 AM
At 15 you can get by with 91 but I don't chance it and run 93 always.
Old 07-30-2012, 09:36 AM
Got Turbo?
PAUERMAN's Avatar
I run 1.5 bar (22 psi) daily and have been for the past 3 years. I use E85 fuel and my Vi-PEC engine management kit. Absolutely no problems and I know it will take more boost without any issues.
Vic Timpauer - www.pauertuning.com Mesa, AZ
944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R
DynaPack Dyno:
358whp/352lbft @ 18.5 psi 91 pump
438whp/430lbft @ 22.5 psi E85
Old 07-30-2012, 10:45 AM
somewhat off topic. i personally witnessed 40psi on my fathers 2.3 liter Ford Mustang SVO. it had a cast iron block, head, and forged pistons...some multi-layer steel head gasket too.
somethings you never forget...
thank god for slicks!
1988 944 turbo
Old 08-01-2012, 03:17 PM
pressure is a small part of the equation. Having more boost does not always mean more power (most likely less).
I make a **** ton more power now with 19psi on this engine than I ever did at 35psi on the old one. To take advantage of more air coming in you need to address quite a few things first, otherwise it is just pressure for the sake of pressure.
This has all been documented through my 1/4 mile trap speeds over the years.
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 08-26-2012, 12:10 PM
333pg333's Avatar
I've hit 2 bar a few times by accident. Usually running E85. I like 2 bar, is very fast!!
Patrick
Youtube 333pg333
86 modified 951
Old 09-03-2012, 02:22 PM
968 GUY's Avatar
How much stress can the rods and pistons take? I'm guessing more than the head gasket.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock
Old 09-03-2012, 07:05 PM
Got Turbo?
PAUERMAN's Avatar
I just did a dyno session today with the 951. I've run 1.5 bar with E85 for a number of years and thankfully the car has been absolutely reliable.
Here's a couple of videos showing comparison runs using different timing values and just a regular run.
951 Timing Comparison
951 Dyno Run
DynaPack Dyno:
Old 09-06-2012, 04:18 PM
Incorrigible
ditch68's Avatar
Very impressive, Vic! I still tell people about my ride in your car. Fantastic. What a beast!
Vic has an engine management system that just completely impressed me.
Jeff
1988 951 all track modded and angry, 2002 Boxster
'88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone.
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field.
Old 09-24-2012, 07:20 PM
