Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
3.2 litre build using the 1989 2.7 944na
Has anyone done the 3.2 litre build using the 1989 2.7 944na engine as the donor? I am told you can resleeve the 2.7 block to accept J&E custom turbo pistons and a 3.0 s2 or 968 crank to come out with a 3.2 or 3.3 litre torque monster easily capable of 450 HP on street fuel while utilising the stock 951 turbo crossover pipe, intake etc.
Does anyone have any accurate info to offer ?
PS.......Is there any difference between the s2 3.0 crank and the 968 3.0 crank??
I was told that the 968 is a better piece!
thanks...........G
Old 08-09-2006, 09:08 PM
i haven't seen a 3.2L motor. however, I have seen a 3.1L, it had an S2 crank (which shouldn't be any different than a 968 crank), and 104.5mm sleeves/pistons.
It was built from an S2 engine and was a 16V turbo.
86 951 millenium yellow - show car
87 951 primer grey - track toy
88 944S guards red - 180WHP - SOLD
Old 08-10-2006, 06:06 AM
Was the guy happy with it?
Would you happen to have his contact info?
Geno
Old 08-10-2006, 07:06 PM
Came across most of what you were asking.
http://www.clarks-garage.com/shop-manual/951_eng_perfmod.htm
I think using a 3.0 block and then over bore, sleeve and using the 944 Turbo head/modified is easiest.
These guys can do it but it cost bank.
http://www.powerhaus.com/944t.htm
I have No first hand experience to share.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 08-23-2006, 01:25 PM
thanks............G
Old 08-23-2006, 05:03 PM
bump
Old 09-06-2006, 04:39 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Chris White over on Rennlist should be able to give you a whole boat load of information on this.
IIRC he said it was theoretically possible to take it up to 3.6L or something crazy like that.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-06-2006, 08:29 PM
Thanks Chris
Old 09-06-2006, 09:08 PM
