Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question need help on camry problem
ran bad ,hesitates,stalls won't start at all now.thought it was bad gas but added dry gas and filled up when very low.last time i got it started i had to clean the plugs first,they looked fouled.makes me think problem is ignition also tach goes to 0 instantly when motor dies.92 toyota camry 4 cyl.any ideas greatly appreciated
Old 12-17-2007, 05:41 PM
Super Moderator
nize's Avatar
asking for camry help in a porsche forum? okay, just an idea: why not ask for camry help in the toyota forum?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-17-2007, 06:04 PM
you know i did that. just trying to get as many ideas as posible.i also own a 944s and didn't know porche owners would be so snobby.
Old 12-17-2007, 06:45 PM
Super Moderator
nize's Avatar
so let me get this straight, toyota owners won't tell you how to fix your toyota and that's okay. but when porsche owners won't tell you how to fix your toyota they are snobby?
what 944's do you own? post up some pics and we'll tell you how to fix them all day long.
Old 12-17-2007, 06:54 PM
don't want to deal with someone that doesn't have anything to bring to the table.i worked as a mechanic for many years, owned alot of nice cars but never refused anyone any knowledge i had if they asked.i think the problem with my camry is an ignition ignitor which all cars with breakerless electronic iginitions have,i just wanted to see if anyone else felt the same before i bought one.
Old 12-17-2007, 07:18 PM
Jump out tc and e1 in the diagnostic connector , count the engine light flashes and get the code . Ps: if it has too many codes to count then un hook the battery cables for the battery positive and negative touch them together for 30 seconds reconnect try to start for a minute or to then jump out the diagnostic connector agian and count the engine light flashes. These cars were famous for distributor failures ( built in coil and igniter in the distributor) Also make sure you never jumped time ( T-belt) 2 nd a 3rd generation Camrys are some of the best built cars ever !! Bottom line , let me Know Davepnola,,, ex Toyota Tech .................................. Oh after u get the code then just type it into GOOGLE U know 92 camry with code 52 and hit enter someone will be talking about it !!!
Old 12-17-2007, 08:12 PM
thanks davepnola i will try your idea and let you know.might be after xmas.this is the help i expected from fellow CAR PEOPLE.thanks again.
Old 12-17-2007, 08:25 PM
Super Moderator
nize's Avatar
i could use some help with my yamaha seca 550, any takers?
or how about my audi 5000s quattro? it's a german car too.
Old 12-19-2007, 11:14 AM
Engine swap pro
myskyon's Avatar
here is for your audi : http://forums.pelicanparts.com/vw-audi-technical-forum/
and your yamaha well i would not ry to HIjack someone elses thread, you could allways try to post up a question about it somewhere on here.
gees
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 12-19-2007, 12:07 PM
You guys are better than the funnies. Bruce
87 951 (All stock commuter)
87 951 (Saturday night Special)
77 911S (token tail dragger)
83 928S (engine back in from tear down, interior gutted)
....Grasshoppah
Old 12-20-2007, 11:00 AM
Anyone know what I should set the valve lash on my Ducati to? And where can I find the shims cheap?
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 12-20-2007, 02:14 PM
Porsche Gonzo
onehot951's Avatar
Send a message via AIM to onehot951 Send a message via Yahoo to onehot951
good point nize. its true by fact that they both have engines and 4 wheels, but i think other than that, and both having a gas cap, the similarities end there. in all seriousness it sucks the toyota guys couldnt help you, i ran into problems like that when i had a merkur. however, in nize's defense its not that were being snobby, its just that the question was asked in a porsche forum. if i were to ask the ferrari guys how to troubleshoot an electrical problem on a mg midget, they would probably respond with a similar comment.
then again if i asked someone with a ferrari about an mg and "electrical problems" they would probably whisper the word "lucas"
at this point i think lucas wired the space shuttle....... GO Atlantis... oh darn another damn power connector problem... scrubbed!
1986 928S (we need an excorsism done here)
1988 944 Turbo (2-14-2000 - 6-6-2008)
Last Video Made in the 944 turbo (5-28-08)
http://www.youtube.com/watch?v=UmjhT7AndEQ
Old 12-28-2007, 06:55 PM
