I beleive its all 951s up to the turbo s had the venturi.
Damn marcone you got lucky they didnt give you that ticket for 2000 |
Super Moderator
this is true. venturi was deleted by the porsche factory starting 87 model year.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Engine swap pro
both my 87's had the ventury tube. i thhink it was 88 they stoped putting it on.
87 951 ---- "R2" - under the knife 87 951 ---- "R1" Parting out - Gave to a good friend 88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out 06 WRX ---- The "RUE" |
My bad...Should read the signature line on the posts. Some 87s had the venturi some did not, but from 88 on wards it was gone. Sorry guys.
Sox
"Little problems always come back and bring bigger friends with them". 1986 951"MADDOG" black Dual port WG, 4 port control valve with EBC |
winter-hater club member
i could have sworn my '88 has the venturi tube.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Super Moderator
i'd be curious if it does. can you post a photo?
let me see if i can find one in my archive.
isn't this the venturi?
don't worry, all that nasty rubber was replaced! ![]()
Super Moderator
that does look like it. odd, it's the first i've heard of a ventiri on an 88.
vott does ziss do?
89
Super Moderator
my first 88 did not have the venturi and i know that was how it came stock. neither did my second 88, though it's possible the p.o. changed it.
In the Fires of Hell.....
I've never taken the intake off of mine, so I can't say either way. Just heard that on Rennlist forum.
What exactly is the downside of having the venturi, other than it removes a bunch of the vacuum hoses? I have seen a bunch of guys advertising "Venturi delete" in their car descriptions, but have no idea what the big deal is. Cheers, Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
The big thing is that it simplifies hoses and lay out. The smaller the number of hoses/connections less to leak and go wrong. As far as I know there is not performance differences. (But the distance of my knowledge some times only extends a few angstroms
)Sox
Super Moderator
the plastic venturi check-valve also fails easily and causes problems when it does.
what kind of problems can the check valve cause? the reason i ask is that a friend of mine with a '87 BMW 325is (i know, i know) is having major idle/power issues and it has an IDENTICAL venturi part.
Super Moderator
idle/power issues.
if i remember correctly, it causes erratic isv operation.
now that we've completely hijacked this thread...
![]() so, you are saying it COULD be the venturi tube? also, the intake boot is very old and cracked. i've already advised him that this should be replaced and thought that was where we'd start.
Super Moderator
yeah, you could verify with a vacuum hand pump.
Iirc it just runs the vacuum to the brake booster...
SOx
Super Moderator
everything you want to know about venturi;
http://forums.rennlist.com/rennforums/showthread.php?p=5022592#post5022592
