Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
One apex at a time
Dean924s's Avatar
Injector Question
Does anyone know the peak and hold amps of stock 951 injectors? This is for my Megasquirt project.
I could also use the same #'s for NA injectors as well.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 07-04-2010, 01:42 PM
Rogue Tuning
Rogue_Ant's Avatar
Well, 951 stock injectors are ~4.5ohm. So at 14volts, that would be a little over 3.1 amps each.
The 944 injectors are ~2.5ohm. Which gives ~5.6amps each.
-Rogue
-Joshua
www.RogueTuning.com
Old 07-04-2010, 02:01 PM
winter-hater club member
nynor's Avatar
criminy. how do you figure this stuff out? electricity is a mystery, mostly, to me. i can use a multimeter for SIMPLE stuff, and usually kill a fuse in it, but that is the limit for me.
"COOL PRIUS!" - Nobody Ever
Old 07-04-2010, 07:50 PM
Rogue Tuning
Rogue_Ant's Avatar
V = I * R
And those numbers are on the high - end. I was pretty much assuming max voltage, and not account for any V drop in the driver circuit.
-Rogue
-Joshua
www.RogueTuning.com
Old 07-04-2010, 09:37 PM
One apex at a time
Dean924s's Avatar
For those that dont know:
Peak and hold injectors (less than 4 ohm) need a initial "burst" of energy to get them to open causing them to open faster than saturated injectors (10-16 ohm).
The initial burst of energy (the peak) is then followed by a lower amperage that is sufficient to hold the injector open. Hence the name "peak and hold."
I assume that those numbers are for the peak number? Does anyone know the hold number? This is usually between 1-2 amp.
Thanks for the fast response!!!!!
One other thing
"V = I * R"
V=Volts
R= Ohms
But
I=Amps?
I always used an "A" Since I have no formal training in electronics have I been doing it wrong?
Respectfully
Dean
Old 07-05-2010, 07:15 AM
All Spooled Up
Yes.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 07-05-2010, 07:33 AM
One apex at a time
Dean924s's Avatar
Originally Posted by wild man View Post
Yes.
I am doing it wrong or it is the peak amps?
Respectfully
Dean
Old 07-05-2010, 08:07 AM
Rogue Tuning
Rogue_Ant's Avatar
I = Amps
And 1-2amps for hold should be fine.
-Joshua
www.RogueTuning.com
Old 07-05-2010, 09:57 AM
