Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Try to fix one problem find another
It looks like the good old cycling valve has two busted nipples on it. Not good. Now I think these are expensive but I'm not really sure. Should I even replace this with another one or just get a MBC and set it to 10 PSI?
What is the cheaper route and would an MBC work with a stock setup. I am 99% stock minus K&N Cone filter.
Old 09-28-2010, 07:24 PM
On Boost
Paulyy's Avatar
IMO while you're underthere buy this VENTURI DELETE at LINDSEY RACING - Your Porsche Performance Parts Center
and replace all the hoses and delete the venturi!
you can go to a MBC but im not sure if it will give you the same protection with the KLR
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 09-28-2010, 07:35 PM
I am doing the venturi delete and replacing all the vacuum lines. Trust me I don't want to do this job again.
Old 09-29-2010, 06:32 AM
On Boost
Paulyy's Avatar
yeah! if you get stuck i have a vaccum diagram i just posted up, it might help a little.
Old 09-29-2010, 06:43 AM
In the Fires of Hell.....
kdjones2000's Avatar
You can usually find one used from a member here or Fleabay for not too much.
Going with the MBC will allow you to delete the Cycling Valve, but as Pauly said, you are taking one of the safety mechanisms out of the system if you experience pinging.
Good luck with your decision....
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-29-2010, 08:19 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
a new timing (cycling) valve is available here from pelican parts, p/n 951-606-117-00-M100, and costs $116.50.
While MBC is available from say Lindsey Racing for about $65.00 as mentioned, it does remove a safety feature from your system. IMHO, unless you are running a modified engine or turbo or doing track work, I'd stick with the timing valve.
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 09-29-2010, 10:07 AM
On Boost
Paulyy's Avatar
some good info here
Manual boost:why not after cycling valve!
Old 09-29-2010, 10:40 AM
