Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Question Solid (not blinking) "code" from KLR?
I hooked an LED to the KLR diagnostics plug after driving around the block a few times and then idling. I'm getting only a SOLID light without any blinking.
Not sure what this means, as the codes listed on Lindsay Racing don't mention a solid light "code".
I should mention that my dashboard warning lights also never leave their "test" state while the car is running (ie, they are all on, all the time). I am mentioning this because I'm wondering if it could in fact be a faulty ignition switch -- could a faulty ignition switch keeping the dash in "test" mode also cause a solid lite "code" to be displayed from the KLR diagnostic plug?
Old 09-19-2011, 04:07 PM
Super Moderator
nize's Avatar
bad wiring? are you sure you plugged the LED into the right connectors?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 09-20-2011, 08:24 AM
Right connectors, right polarity.
Old 09-20-2011, 08:36 AM
All Spooled Up
I get the solid "blink" only when the TPS is disconnected. Other than that, I've never seen it actually blink a code.
Don't forget that the DME on these cars is OBD0 (there are no on-board diagnostics, other than through the proprietary connector, which doesn't use standard OBD signals). So if there IS a TPS issue, you aren't going to see any dash light come on.
Maybe the KLR code list should be updated to include that a steady-on light incicates a bad (or disconnected) TPS.
That IS assuming that MINE is working correctly.
Can anybody confirm this?
Old 10-09-2011, 07:27 AM
All Spooled Up
Hey clay, did you try re-seating the TPS connector, visually inspect the wires, and test the TPS with an ohm meter? I think the procedure for that is on clark's. If not, try the944.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 10-10-2011, 06:13 AM
Tags
951 , code , electrical , fault , klr
