Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
In the Fires of Hell.....
kdjones2000's Avatar
If you pinch off the hose going directly to the WG, you should be able to get boost up to whatever will grenade your engine, even with a stock WG setup.
Sounds like either your WG has failed, or your crossover pipe has collapsed.
How does the engine run when on boost? If it's choking, then it's likely the crossover. If not, then I would look at the WG.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 10-30-2019, 07:38 AM
Good to know as I get about 1.8 BAR fully pinched off.
Checked WG and its good 5psi to open 11psi fully open. The only thing I haven't checked is the Crossover and the CAT pipe!!! I had the Downpipe off 400 miles ago and it looks perfect! Engine does not choke on hard acceleration.
Mike G.
Old 10-30-2019, 10:21 AM
Used an endoscope for iPhone and here is what the Crossover pipe looks like going in from the Waste Gate "T". Looks good but its kinda difficult to get a good view farther down the pipe.
P.S. I've got an aftermarket CAT. Are these typically straight thru? If so I'm going to try the scope going from the rear of the car.
Why doesn't it show my pic. I attached it with IMG from smugmug???
Mike G.
Old 11-01-2019, 08:27 AM
FYI CATs don't go thru!!
Mike G.
Old 11-01-2019, 12:07 PM
LOL ... but seriously a scope is not gonna work?? If you constantly run rich at part throttle and idle, you'll cook it!
But a lot of crap would have had to been blown out for you to see daylight thru one??? I doubt that ever happens but if the honeycomb structure has broken down it will tend to rattle over bumps and stuff??
Anyway ... here's a good clip and most likely more that you wanted to know.??
https://www.youtube.com/watch?v=v9ju2rZ8YmM
Old 11-02-2019, 01:18 PM
I'm going to try something else now. I'm going to put a vacuum on the WG hose to insure the WG is not opening at all or much less. I still believe that the WG is the culprit even tho it tested ok with 5 psi to open and 10 psi full open condition.
Mike G.
Old 11-02-2019, 02:08 PM
Lazy mans update!
I unplugged the power to the CV and 1 BAR absolute was achieved. So I still thinks its the wastegate! Just not ready to dump $450 into a trail test!
Mike G.
Old 11-03-2019, 10:19 AM
Mike G.
I think on here you have to use the "Click Here to Upload Photos" button where it says attach a photo?? I've done it and it seems to work fine.
Old 11-03-2019, 01:46 PM
DOH!!!!!!!!!!!!!
Crossover pipe looking from WG "T" off towards Turbo!!
Mike G.
Old 11-03-2019, 02:06 PM
Just ran a test pulling 15in of vacuum on the WG hose to help keep the WG valve closed. Makes a huge difference. Can reach 2 BAR absolute easy!!! Tried to keep it to 1.8 in 1 ,2, 3 gears. Makes me think the WG is the culprit!! BOO!!!
Mike G.
Old 11-03-2019, 03:15 PM
dme dme is offline
You can always add shims to help tighten the springs. A manual boost controller shouldn't even let the WG see boost till you near your desired level.
Dan
86 Guards Red 951 (the best so far)
86 Black 951 (sold 12/31/09 PITA)
86 Guards Red 951 (sold in 7/15/00 (first love)
90 Plymouth Voyager, 2.5 Turbo 5 speed
Old 11-15-2019, 09:44 AM
I was thinking about this and I came to the conclusion that I wouldn't be able to reach my desired boost level even with a MBC. Reason is that I've already pinched off the WG hose and still could barely reach the 1.8-2 BAR. So its either a WG spring that sagged or the CAT pipe. I'm going to try to get my **** together this weekend and check the CAT pipe.
Mike G.
Old 11-15-2019, 12:14 PM
Added 1/8 inch shim to WG and now getting about 1.6 BAR. Need to test on fwy tomorrow morning in higher gears. BTW there is a noticeable difference in acceleration. Wouldn't have thought so.
Mike G.
Old 11-21-2019, 06:44 PM
soxnail's Avatar
Had similar issue, was a clogged catalyst.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black
Dual port WG, 4 port control valve with EBC
Old 11-30-2019, 08:07 AM
Sox
The Cat has less than a 1000 miles on it
Mike G.
Old 12-02-2019, 08:09 AM
Added another shim for a total of 1/4 inch!!! Still didn't reach 1.8 BAR!!!
BOO!!
Mike G.
Old 12-08-2019, 08:42 AM
dme dme is offline
I picked up an OEM waste gate off of eBay that had 5 shims on it!
Dan
Old 12-08-2019, 10:17 AM
Mike's wastegate is fine, one of the best stock ones I've ever seen. Tests fine. It's not issue. With this strong of wastegate, pinching off line should generate 20-25psi boost no problem!
Problem is there's excessive exhaust backpressure forcing wastegate open or turbo to not spin.
- Either crossover is collapsed. Most likely issue as I've replaced over 5 of these over the years.
- exhaust clogged, not likely. Modern cats are ceramic and do not melt with heat to cause restriction.
- or turbo is worn-out with dragging bearings or wobbling has caused extra clearance at edge of blades. This could be possibility.
Grab turbo's axle and wiggle it up & down. How much radial-play do you feel?
Old 12-09-2019, 10:03 AM
Looked as far as I could with a bore scope on my cell phone and it looked ok, but I guess I need to take it off and really check it out. Unless there's another way to do a lazy A$$ check!
Turbo rebuilt by evergreen less than a 1000 miles ago!
This is starting to wear me down a bit!!
Mike G.
Old 12-09-2019, 03:55 PM
Just because the turbo was rebuilt recently does not mean it is in good condition. I have had new parts that are bad right out of the box. The best rebuilders do make mistakes. Or maybe something went through the exhaust and damaged the turbo. Remove the j boot and look at the blades, also try and wiggle the shaft - both right - left and in - out. While the j boot is off check it for any cracks.
I would do a pressurized leak test to check for vacuum leaks. If you have a big leak you will never get full boost. With wastegate out of the picture you should run unlimited boost. Since you are not it comes down to turbo working properly or air leak or restriction.[img]http://forums.pelicanparts.com/uploads2
6/20191211_1612351576098852.jpg[/img]
Here you can see a split in the bottom of the hose coming from the aos into the j boot. Not visable, but will cause slow spool and low boost. Visual inspection is not good enough.
Old 12-11-2019, 12:18 PM
