Send a message via AIM to Adidas
Need Advice on 3.6 engine with low compression
Hey Guys: Need some advice. I may have the opportunity to purchase a beautiful 93 911 cabriolet. This car has 259,000 miles on the odometer. The previous owner had the engine rebuilt less than 15000 ago by a Porsche shop in the area. I have checked the invoice and it appears that the pistons and cylinders were not replaced. The shop just replaced the rings. I ran a cold compression test on the engine with the results below
Cylinder#1 50lbs spark plug oil fouled
Cylinder #2 70 lbs
Cylinder #3 160lbs
Cylinder #4 155lbs
Cylinder #5 165lbs
Cylinder #6 190lbs
Cylinder #1 spark plug is the only one oil fouled. The other plugs are normal. Is it worth a shot to repair the 2 low cylinders. My plans are to only keep the car for the summer then put it on the market. Thanks in advance. William.
Old 04-25-2007, 10:17 AM
AFJuvat's Avatar
Walk away
You would drop a few thousand into the repair just to turn and sell it - with that kind of mileage, it may be hard to get your money back.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-25-2007, 11:21 AM
Sports Purpose 911 Driver
mjshira's Avatar
good advice.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 04-25-2007, 04:24 PM
