sgoldberg's Avatar
964 engine Management System
I have a 1989 964. I am replacing my stock engine with a 1993 RSA motor. The motor comes with the brain and proformance chip. I was told that a new engine management system would be very useful ...Haltech etc. which is the best system for my car and what are the cost I could expect to have the system installed?
Thanks,
Shelon
1989 964 C4- Fikse Wheels -B&B Headers & Muffler - GT3 Seats -RS Door Panels - Club Sport Steering Wheel
Old 02-18-2008, 06:19 AM
Bill Verburg's Avatar
There are lots of choices, none are cheap. Also depends on if you are keeping the stock intake manifolds or using something different.
Motec is one of the most highly regarded
Bill Verburg
Old 02-18-2008, 08:27 AM
sgoldberg's Avatar
Thanks Bill - The stock intake will remain on the car.
Old 02-18-2008, 09:42 AM
Tom W's Avatar
Like Bill says, it's not cheap. Select the management system that your shop is going to be able to support. My shop uses MoTeC so it was a lot less problem to switch to MoTeC than to try and get the Motronic system programmed/re-programmed. A MoTeC conversion is likely to run close to $5k for the ECU, wiring harness, and programming time.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 02-18-2008, 03:02 PM
sgoldberg's Avatar
Thanks for the info. I guess a chip is my inline with my budget.
Old 02-18-2008, 03:50 PM
You are in New York so you should contact Jimmy at The Shop. He is a dealer for Accel Gen 7's.
Old 02-19-2008, 12:05 AM
sgoldberg's Avatar
Do you have Jimmy's contact info? Thanks
Old 02-19-2008, 02:22 PM
www.theshopct.com
Tell him Eric Hood sent you
Old 02-19-2008, 04:50 PM
930gt-40r's Avatar
Yea, he does all of those nasty DFI installs.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 02-19-2008, 07:16 PM
Thanks,
Shelon
Why do you think you need a standalone? Is there a issue with the Motronic system?
Old 02-22-2008, 01:03 PM
930gt-40r's Avatar
I wouldnt bother unless you were going to blow into the motor.
Kris @ Tech9
86' 930/GT-40R Sold
Old 02-22-2008, 06:00 PM
sgoldberg's Avatar
I was told that a new engine management system would release hp on the motor. So I figure i would investigate and see what the costs are.
Old 02-24-2008, 06:26 AM
There are ways to gain control over the factory Motronic engine management. Some of the things that are available for the 964 are: MAF conversion, support to larger injectors, support to LWF and access to fuel and ignition without going the standalone route. If you need more information send me a email.
Old 02-24-2008, 08:56 AM
I know this post is old, but I would like to retract my recommendation! DO NOT USE Jimmy Kakaletris owner of The Shop in Norwalk CT. I am beyond mad about my latest experience with him, and his shop!
Old 01-31-2009, 02:05 PM
