Alignment Question
![]() Will soon need alignment for C2S with pss10 coilovers. First I will set ride height, understand that any alignment changes once ride height is set will change alignment. I need to decide which wheels and tires should I use when alignment is done. Tires on each will be different brand but same size. Also if I put on slightly different wheels and tires i.e.. (sized) will that change the alignment. |
different wheel and tires sets won't measurably affect alignment
With the ride height adjustability of PSS10 You should consider setting/checking corner balance when setting ride height and before you align.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
