Worn front sway bar drop links
Hi all, How difficult is this to replace these myself? Or, do I need specialized tools to do this?
What about alignment after replacement? Thanks!
Old 07-31-2015, 05:29 PM
me too
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 07-31-2015, 08:06 PM
Bill Verburg's Avatar
You can DIY, they do not affect alignment
The hardest part is getting room to screw into the wheel carriers
Bill Verburg
Old 08-01-2015, 05:04 AM
Should I just replace these or are there other bushings/parts that I should replace at the same time...I just replaced the wheel arm bushings and shocks/struts...
Quint
Old 08-01-2015, 10:07 AM
all the bushe should be replaced after so many years, the '95 are now 2 decades old
for best combination of ride and performance
use Elephant sport bushes on at least the trailing legs of the front A-arms, on the leading legs too for best results
use RS rear A-arm and KTs arms(Elephant sport bushe can also be used here), use normal camber and toe arms and bushes, though the toe arms can be stiffened w/ either sport bushes or even mono-balls if the car is tracked.
Bill Verburg
Old 08-03-2015, 11:06 AM
Ok. But how do get it out , with the hub on the car
1992 964 C2 turbo
Old 08-05-2015, 08:32 PM
