Cobalt's Avatar
Originally Posted by Bastin View Post
I've got two spare units lying around for my '94, and Porsche charges an arm and a leg for rebuilt ones - like $3000 plus a $900 core charge. These would be a huge score if they work, If I can get functional ones for under $100, that's a massive savings. Fingers crossed
I as well however Porsche no longer sells the EZ69 units and when they sold the BX rebuilt units version which were problematic they were $7800 with a $5k core charge. That had to be 10 years ago. These are NLA from Porsche. Last I saw one sell for was over $5k on Ebay.
There are sites claiming to sell them however Porsche has no inventory and I suspect if you try to buy them they will tell you they can't get one.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 05-08-2025, 11:01 AM
Banned
Will the 3.3T and 3.6T EZ69 come in different versions? Thought there were some key differences between the two. Maybe a single unit with multiple maps?
Old 05-10-2025, 04:06 PM
Any updates on the development on these units?
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 06-16-2025, 12:09 PM
umop apisdn
Prototypes are currently undergoing durability testing, and although indications are we have a viable product from an engineering viewpoint, there is still much to do.
Next step for us is the pre-production evaluation phase, and concentrating on manufacturing viability. e.g. refining the upper case to eliminate several of the CNC machining steps required for the prototype phase.
The tiny potential market for this and the physical complexity and dimensional tolerances of the module have this silly project jammed well and truly in the "must be near perfect or don't even try" zone.
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 06-17-2025, 04:10 AM
Thank you kindly for the update Steve. I certainly will be suggesting to everybody I know plus on 965 owners reenlist to buy one and put there original unit away in storage. I feel your new unit is a must have for all 965 owners. I had one go bad on last year, Thank god I had spare. if not my 965 would be a paper big weight waiting to find another unit. Thank you again for all your work to develop these.
1992 964 C2 turbo
Old 06-17-2025, 08:35 AM
I’ll take one as well! Much needed as my 94 turbo will die if you shift to neutral while coasting to a stop. The car then won’t start for some time
Old 07-05-2025, 10:06 AM
Any update on this? I just bought a 964 3.3 Turbo project and although I don't know if I need one of these, I wouldn't mind having one for when I do.
1991 Turbo
1997 Turbo
2004 Cup
1996 C2
1989 C4
Old 07-21-2025, 03:37 PM
Anyone? Bueller..,..
Old 08-07-2025, 05:34 PM
Hi Steve,
I hope all is well. any updates?
1992 964 C2 turbo
Old 08-12-2025, 07:53 AM
umop apisdn
Hi All,
Nothing definitive to report yet.
Most of our time is being split between refinements for possible production and reverse engineering the ignition maps out of the 01 EZ69 and various Mercedes units.
www.FrankenCIS.com
Old 08-12-2025, 09:10 AM
Thank you for the update
1992 964 C2 turbo
Old 08-12-2025, 09:52 AM
Thank you! We’re patiently waiting!
Old 08-14-2025, 09:51 AM
umop apisdn
UPDATE,
As part of the EZL/EZ69 development, we have unfortunately discovered a little issue the Mercedes EZL as a cheap option.
The fuel coding signal (mercedes) is on the same pin as the Porsche charge air temp sensor is on the 965.
And the resistances are inverted between the Mercedes coding and the Porsche sensor!
Therefore, as the intercooler heats up, ignition timing could advance by up to 6 degrees instead of retard by up to 2.8 degrees.
Not good if you are wanting to protect the motor.
The 538 and others are still likely a good candidates for a "Get me Home" emergency spare to keep in the toolkit, but really not a good choice for extended use.
www.FrankenCIS.com
Old 08-17-2025, 05:31 AM
umop apisdn
Reverse engineering the maps is showing promise, but we have some variables in the bench test setup that we must eliminate. Digital replication of the input signals is fine for development but we can't be confident of any results unless the correct real world inputs and outputs are connected.
Thus the above contraption is about to travel from it's home town to us here in Oz and be retrofitted to run a proper flywheel trigger setup and generate vacuum and boost pressure, while firing actual spark plugs etc. Essentially a desktop engine dyno.
The 01 EZ69 we have here is not yet confirmed as functioning properly and there is a chance it is unhappy with the dummy ignition coil load we are using on the bench or it has a faulty temp sensor input, either way it is 7-10 degrees retarded from where it should be when above 2500 rpm.
So, fingers crossed connecting a proper 965 ignition system might pull it out of safe mode and we can move forward.
Chances of our module having a preloaded factory map -- maybe 50/50 at best
Let the weird futility continue
www.FrankenCIS.com
Old 08-22-2025, 11:50 PM
Is it correct to assume that the ez-69 either works or it doesn’t? There is no intermittent working vs not working?
Old 10-16-2025, 05:22 PM
umop apisdn
Generally yes,
the primary failure is on the ignition coil output, which overloads and destroys itself.
The Ignition transistor fails in two ways, it either goes open circuit, like a blown fuse, and simply stops the spark from working or it shorts out and then kills the rest of the EZ69 by letting 12 volts run around all over the boards inside.
The 01 EZ69 I have here seems to have a different fault where the temperature sensor input has failed. So although it is still working, the timing has gone into an engine overheat temperature limp mode for safety. ( the 3K one on eBay a little while back)
Intermittent faults are logically possible now that the units are 30+ years old, and I've run across some chatter that suggests it's happening. I also have a rare Mercedes 24valve one here that may fall in that category but we've not had a chance yet to look at it properly.
www.FrankenCIS.com
Old 10-16-2025, 08:58 PM
Generally yes,
Besides the key factor of its being a bad design, i.e. a hybrid circuit, and installed in the engine compartment, it's failure was predictable.
Dave
Old 10-20-2025, 09:44 AM
umop apisdn
I came here to post an update, but I'll have to stop laughing first.
Could take a while.........
www.FrankenCIS.com
Old 10-23-2025, 11:53 PM
Your knowledge of Porsche electronics appears somewhat limited, i.e. many of the Bosch 3 pin CDIs from the early '70s (55 yrs old now) are still functional.
This is in contrast to EZ69 design which was domed to fail, especially in an engine compartment with temperatures exceeding 100C.
Remember, the Mercedes Benz versions have a very low failure rate versus the Porsche EZ69 part! Those modules operate in a less severe environment.
Where is your proof-of-concept development circuit board actually running a Porsche Turbo? Surely you have one, as a necessary step for any
complex electronic circuity development, especially for a 965 ignition system. Post #54 describes a setup running on a test bench,
but not actually running a 965 motor, or even driving an ignition coil - a critical development step.
Dave
Old 10-24-2025, 10:10 AM
@mysocal911 I have a 965 running motor and would be ok trying the new units. And I’m in socal
Old 10-25-2025, 06:16 PM
