umop apisdn
![]() https://www.plex-tuning.com/products/plex-knock-monitor-v3/
Steve 1981 928S 4.7 ROW with KE3-Jetronic "Be the man your dog thinks you are." www.FrankenCIS.com |
Helio Lopes
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
umop apisdn
development progressing,
Wow ! those are sexy. Great work
Please email me once you you have a working unit ready to test or sell. i own a 1992 964 turbo stock with a RUF wastegate spring of 0.9 bar. I assume those work on bothe the 3.3 and 3.6 turbo's ? I live in the Washington DC area. contact info heliolps2atyahoodotcom. Thank you kindly Helio
Amazing - I don't mind them being in your case design instead of inside an old B case.
Are there any heat or grounding concerns as with the originals? Will be curious about the programming as well, though I have a stock car with just free flow cats. Yes the 3.3 and 3.6 964 turbos were a different map, assume you're making these mappable to all the various specs of cars they were used in to have the largest market.
73 911s Targa / 94 964 Turbo 3.6 / 77 Guzzi Le Mans / 93 Guzzi 1000s / 73 Guzzi V7sport / 77 Yamaha DT400 / 06 Ducati Paul Smart / 15 MBZ G550 / 01 Range Rover 4.6 |
Can't wait to buy one for my 3.3
Hello, thanks for working on this problem. I have a 964 3.3 Turbo that's been sitting for two years because there's no 1969 version available. If anyone can help me out for a while, that would be great. Otherwise, I'll have to wait until the replica is available.
Thanks, Dirk |
big boost connection
Best Regards |
What does a "refurbished module" mean?
Dave |
Please post some images of "repaired" units. Thanks
Dave |
Hello Thomas, I'm sorry i didnt recognize you. I sent you a message. Please email as well. I need a EZ69-01 for my 1992 965. I heard the EZ69-02 will work on the 3.3, Is that true?
02 runs I. 3.3 but it works with a different ignition angle and because of no knock detection on this engine it’s risky.
Iam happy that you still own the car with my engine and trans pack✌️ |
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/886233-even-trade-92-965-my-97-993-cab-hmmmm.html https://rennlist.com/forums/964-turbo-forum/990555-traded-my-993-cab-for-92-965-a.html ![]() I had someone contact me about your shop, I told him that I done business with you and it was a great experience. and to trust you. Thank you again. Just to let you all know, I bought a complete 965 engine and trans from Thomas at FSR Auto sport and had him ship it to me in Virginia from Germany, by air, it went smoothly. I can't say enough about the experience. Check out his shop in the Porsche motherland, It's amazing . I highly recommend FSR Sport Auto https://www.fsr-sportauto.de/ and follow him onhttps://www.facebook.com/search/top?q=fsr-sportauto or https://www.instagram.com/fsr_sportauto/ Thomas please let know how to get a EZ69-01 as soon as possible please send the info via email. heliolps2atyahoo.com or message me
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo Last edited by heliolps2; 04-15-2025 at 12:46 PM.. |
Banned
It’s a tricky one for sure! If you’ve been searching for months with no luck, you might have already seen that new ignition modules are pretty scarce. A few people have had success sourcing used ones, but you’re right, the physical difference is minimal, so using the MB (96560270602) could work as a temporary solution, especially if you can match the pinout and connector.
Dave |
Greetings,
I would also like to know about these repairable units. I have a 964 3.6 turbo in my shop and can't seem to find a solution to these modules |
I have 2 spares in case you run into a dead end but it is pricey.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Banned
I've got two spare units lying around for my '94, and Porsche charges an arm and a leg for rebuilt ones - like $3000 plus a $900 core charge. These would be a huge score if they work, If I can get functional ones for under $100, that's a massive savings. Fingers crossed
