umop apisdn
Originally Posted by Cobalt View Post
info about the processor chip in your ez68
https://pdf1.alldatasheet.com/datasheet-pdf/view/66066/INTEL/8751H.html
The 8751H is an EPROM version of the 8051AH.
It has 4 Kbytes of electrically programmable ROM which can be erased with ultraviolet light.
Is fully compatible with the 8051AH but incorporates one additional feature: a program Memory Security bit that can be used to protect the EPROM against unauthorized readout.
The 8751H-8 is identical to the 8751H but only operates up to 8 MHz.
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 09-22-2023, 08:52 PM
umop apisdn
Fourth revision has been approved and sent to fabrication.
www.FrankenCIS.com
Old 09-23-2023, 12:36 AM
Cobalt's Avatar
Thx
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 09-23-2023, 07:05 AM
I picked up these units years ago when ANDIAL shut down. I sold one of the units To Maverick over on rennlist. The two are marked EZ68 and have the number 58 on them. I am assuming these were used on the Brumos #58 car at some time.
I have no idea what the chipsets are and how to read them but if the remaining unit I have will help the cause I am happy to lend it. I do recall the unit I have did not work as well as the second in his 3.3T so it might not be anything that can help.
Neil
Do you recall these and f they might be of help?
I believe adapters were needed to make the plugs work.
Thank you. I know nothing about the factory part. I do remember this engine project when I worked at Andial. However, those units were delivered from Germany and we had nothing to do with their inception.
Any time you add aftermarket parts you run into plug and wiring issues. In this case we had no other way. It solved a problem and worked well. The customer was happy as his car sat for over 1 year while a solution was found. We solved the problem in days and he was very grateful.
Old 09-24-2023, 07:23 AM
umop apisdn
Remember anyone saying "math might save your life" ?
I guarantee it wasn't an engineer.
defining accurate pin placement for the connectors involves this :-
www.FrankenCIS.com
Old 09-28-2023, 06:40 AM
What has happened here, Digital WUR plus? ( FrankenCIS ) lately?
Dave
Old 10-01-2023, 08:49 AM
umop apisdn
FrankenCIS is still going strong out there in the real world, not much activity on the Pelican thread though.
What we are doing for the Mercedes folks with the EZL, will pretty much become the new version for them.
No Microsquirt and direct control (optionally) for the KE-Jetronic on top of the EZL ignition.
www.FrankenCIS.com
Old 10-01-2023, 09:26 AM
umop apisdn
www.FrankenCIS.com
Old 10-02-2023, 04:41 AM
What's the link to the product description and availability?
Dave
Old 10-02-2023, 06:19 AM
Surely, you'll be adding knock-control thru the multi-connector, right?
Dave
Old 10-02-2023, 06:29 AM
umop apisdn
The EZL is still under development, but the primary requirements in order of importance are :-
  1. Plug and play - no wiring changes
  2. Looks OEM
  3. Ignition tuning
www.FrankenCIS.com
Old 10-02-2023, 08:59 AM
  2. Looks OEM
  3. Ignition tuning
As a 965 owner, I so excited to see what you come up with. I just used my last spare
Please PM once you have working' unit available.
Helio Lopes
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 02-08-2024, 07:49 PM
Many people on Reenlist 964 turbo owners that use these units are mostly on that site. It would be good for the 965 Ez69 owners to see what you have developed. You will have great success there.
Please start a thread there. You will have plenty of customers there.
Helio
1992 964 C2 turbo
Old 02-08-2024, 08:42 PM
umop apisdn
Shall do,
The Hardware is running on the bench and the firmware core is functionally complete.
The design and implementation is closely following OEM features and requirements with a few modern tweaks to enhance reliability and protection.
Case and connectors are not yet finalised. As we back-and-forth with suppliers, specs have been refined to match manufacturing realities.
So we are frequently deciding on little details, and then rinse-repeat.
Also, everyone, please hang on to your dead ones as we might also be able to do an exchange program for the EZ69 case.
The schedule has us well placed for in-house vehicle testing of two different prototypes by early April, so maybe mid-year for one or more hand-built units to escape the lab.
poor little naked one on my desk now
and our calibration software connected
www.FrankenCIS.com
Old 02-08-2024, 09:14 PM
Shall do,
Thank you for the update. This is so exciting. We appreciate you hard work! Are you going to start a thread on the Pelican 911 turbo and Reenlist 964 Turbo forum?
1992 964 C2 turbo
Old 02-09-2024, 07:46 AM
umop apisdn
Thanks,
As for a dedicated thread, here or elsewhere, I want to make sure we actually have a viable solution first.
www.FrankenCIS.com
Old 02-10-2024, 07:55 PM
Thanks,
Hi, I hope you had a few productive few weeks, any updates?
1992 964 C2 turbo
Old 03-23-2024, 09:32 AM
umop apisdn
Hi,
Nothing definitive, physical aspects of case and connectors are the current focus.
As expected, bespoke parts are required for 95% of the module.
Still on track for physical on engine beta testing mid to late April (Mercedes)
www.FrankenCIS.com
Old 03-23-2024, 11:57 PM
WOW. I had no idea this was happening. Holding onto spare cases for sure.
You might also be able to use MBZ cases from dead units as they are so plentiful. Perhaps there are differences on the vac hose sensor though, maybe that's also being replaced...
GENIUS WORK pls carry on!
73 911s Targa / 94 964 Turbo 3.6 / 77 Guzzi Le Mans / 93 Guzzi 1000s / 73 Guzzi V7sport / 77 Yamaha DT400 / 06 Ducati Paul Smart / 15 MBZ G550 / 01 Range Rover 4.6
Old 04-27-2024, 03:07 PM
umop apisdn
the crazy continues...
CNC finished upper housing from a formed blank of PA12-F nylon allows the 3d features such as the manifold pressure port and programming connector, the CNC steps then work with the required 0.5mm wall thicknesses between the main connector pin voids and keyways.
www.FrankenCIS.com
Old 04-28-2024, 12:38 AM
