How To Tell If Have LSD? For AX Classification (PCA GGR)
This is a dumb question, but how do I tell if my car (1989 Carrera) has a limited slip differential? I classed myself, ended up in AX13. Then as I was reviewing the results, I saw that I had denied having LSD, and that is a 30-point mod. I want to make sure I'm being accurate.
Also, where do I get the point deduction for the child seats?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
John,
Simply jack up the rear of the car (both rear tires off the ground) and spin either side's tire/wheel ... if the opposite side's tire/wheel moves in the SAME direction as the tire/wheel you are moving, then you have Limited Slip... If the other tire/wheel doesn't move at all, or moves in the opposite direction, then you don't. Hope this helps,
Chuck Miller '73S cpe #1099 - Matched # 2.7/9.5 RS spec rebuild '67 Malbiu 327 spt cpe - Matched # L-79 rebuild Creative Advisor/ Message Board Moderator - Early 911-S Registry R-Gruppe #88 |
When you talk to the houseplants, do they talk back? If so, you have LSD. If they're going door to door on bicycles, you have LDS.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Look in your owners manual or open the trunk and look up at the under side of the hood. In both places should be about a 3x5 sticker with all the option codes for your car. 220 is limited slip.
email speccar@verizon.net Thanks, Mark |
PRO Motorsports
Thom, speaking of LDS, if you're a fan of Trey Parker and Matt Stone, you gotta rent "Orgasmo". It's twisted and wrong, but in a good way. Funny as hell.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Check your option tag as noted above, that's how I found out I had it. Sure wish I could actually make use of it though
![]() I'm getting there.......slowly! -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
No LSD, so I'm not a cheater.
Just dump the clutch and hit the gas on a dirt road and take a look back behind you and tell me what you see.
How would a TB diff (Quaife) respond?
- Colin GTC Motorsports, PCA Club Racing National Scrutineer '92 Euro Cup #96ZNS498058 (PCA GTC1 #19) Past '91 C2 Turbo (PCA D Class #38), '04 Cayenne S, '74 914-6 3.2 (236rwhp), '02 986S M030, '71 914-4 2.1, '76 914-4 2.0 |
Good question Colin,
I never tried spinning one on jacks... I would assume it would act the same as a LSD Cheers,
