Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Adding front oil cooler, in series or parallel?
Might add an additional cooler to my 930 for next seasons HPDE. It was running slightly hot, when ambient temps were high...
When you add a front cooler, I assume you leave the wheel well cooler in, right?
So, is the front cooler then plumbed off the existing lines in series, or in parallel?
I would think that in series, you increase resistance to flow, so you might decrease flow?
In parallel you decrease resistance, so would that decrease oil pressure?
Also, what adapters are folks using to tee off the original fittings? Seems like most of the pics I found on the net bypass the original cooler, which seems counter productive...
My car also has the strakes in back before the wheel wells... Anyone ever add an additional cooler back there? Seems like it wouldn't be too difficult to tee off the brass oil cooler lines after the thermostat to do that, and it would actually use the strakes for something !
Also, lots of places sell oil coolers. The ones for American race cars are pretty reasonable, much cheaper the Sertab/Elephant Racing/etc. Any reason not to use one of those?
Old 09-06-2016, 08:21 AM
Cory M's Avatar
My 87 930 had front oil cooler plumbed in series with the factory fender cooler. Never ran hot.
Old 09-06-2016, 08:40 PM
Most run in series. I believe Elephant's coolers have bigger inlets and outlets which help flow. The other benefit is their stuff is engineered specifically for your car, you can buy a kit that includes all fittings and brackets. To some not having to make your own lines and figure out mounting is worth the extra couple bucks.
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 09-07-2016, 07:25 AM
Charles Freeborn's Avatar
Series. Elephant products are excellent, as is their customer support. You can get their products from this forum's host.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 09-07-2016, 10:38 AM
Pete R's Avatar
These guys are right. I don't know about your car per se but after having put a couple oil coolers in different cars I can say if someone makes a complete ready to install kit.. BUY IT. Cooler fitment, routing hoses, attaching ends becomes quite labor intensive when your not following a designed plan. It's well worth a few extra bucks if someone else has already figured out the details.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 09-08-2016, 06:04 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Running them in parallel makes for a lot more plumbing. You would need to split the supply line with one of these Y-manifolds, then route the hoses to the inlet side of each cooler. Then each cooler outlet hose would have to run back to another Y-manifold that merges the two outlets into a single return hose.
http://www.petersonfluidsys.com/plumb_yman.html
The 911 oil pump is pretty robust, especially your 930 pump, and you should have no problem running the two coolers in series.
Kevin L
'86 Carrera "Larry"
Last edited by KTL; 09-08-2016 at 10:00 AM.. Reason: forgot to add the link for Peterson manifolds
Old 09-08-2016, 10:00 AM
Thanks guys, in series it is...
Will look again at the Elephant stuff... Was hoping for a less expensive option...
Old 09-08-2016, 10:25 AM
BoxsterGT's Avatar
Porsche Crest
Here is what I made up for Paul K (krasuskyp on Pelican) for his 87 930.....
Photos were taken during installation. He already purchased a very reasonable priced Setrab cooler with AN fittings and I supplied the M30 hoses with my crimped "Direct-Connect" AN fittings at the cooler. The system is routed in "Series" and has worked well on both street & track.
A factory level system at a reasonable price. Perhaps Paul will chime in on his experience with this.
Len at Autosportengineering dot com
Old 09-08-2016, 11:50 AM
Can you comment on what you used, where you got it, and cost? Do you have a link? Do standard AN fittings work?
When you connect the rubber hose to the fittings, are crimp connectors considered adequate? (Not talking about the screw on hose clamps, rather, permanently crimped connectors)...
I see tons of oil coolers for sale for domestic cars for $150, designed for race applications... Can't speak to quality, but I would think they would be adequate?
Old 09-08-2016, 01:15 PM
Banned
I worked with Len to fab up a setup that worked out GREAT.
As he said, I sourced a Setrab 172 on ebay quite reasonably. You are correct, ANY properly sized oil cooler will work fine. Line in / out placement and size are the constraints as fitment is within tight confines.
I purchased Elephant's brackets I believe (Len sourced them for me), and Len made me the requisite lines to plum to my OE fender cooler.
As Len stated, works great - street / track.
Any more Q's, feel free to call 860.490.9808.
Len is *the man* when it comes to these lines, as well as fuel lines. I've got his fuel lines in too, and just perforated another f'ing one yesterday so he's dropping me one off tomorrow - how's that for service!? (I'm fortunate to be somewhat proximate)
Hope that helps...
I'd post pics but some say my pics don't show up here anymore, some see them some don't - no idea wtf's going on w/ my Google+ / Picasa acct...
Old 09-11-2016, 08:01 AM
Len, do you have a link to how to order and cost? Couldn't find on your website...
Bo
Old 09-11-2016, 04:44 PM
BoxsterGT's Avatar
Porsche Crest
As above, please email me: Len at Autosportengineering dot com or click on my Registered User name in upper left corner.
Old 09-12-2016, 06:02 AM
Super Moderator
cstreit's Avatar
I would imagine that running them in parallel might not work anyway. The oil will take the path of least resistance, meaning the cooler with the highest flow. ...so the second one might do very little to help.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-13-2016, 05:32 AM
svcetiquette's Avatar
Chris is right on - without a means of restricting/forcing flow through both coolers, friction in the longer piping run would hinder flow to the distant cooler, which would be exacerbated by the increased viscosity of the cooler oil in that piping run, cooler, and return piping.
Todd.... '86 930, DC13s, TK I/C, GT-35, Rarlyl8 Headers and Muffler
“The only thing we learn from history is that we learn nothing from history.” ― Georg Wilhelm Friedrich Hegel
Old 09-13-2016, 08:21 PM
Thinking way back to physics class and fluid dynamics...
Flow is proportional to resistance, I think. So if the resistance in one oil cooler were twice that of the other, it would get 1/2 the flow...but it would still get flow...
By having 2 coolers in parallel, you are dropping downstream resistance, which might actually increase total flow to the coolers...therefore increasing total cooling.
Sounds like putting them in series is tried and true. But I do wonder if doing it in parallel would work better...
In series, oil that has already been cooled off by one cooler, now goes into the next cooler. The difference in oil temp to ambient temp is lower, so the second cooler "cools" much less...
Most cars have their coolers set up in parallel. Think of a bugatti, with its 8 coolers or what have you. They are not in a row, rather, in parallel. Same with the Ferraris: 2-4 coolers, one to two on each side, in parallel. NOT in series.
Same with radiators in pick up trucks. The water coolers are in parallel, not in series...
I suspect that in the 911's added oil coolers are added in series, because its easier... not necessarily "better."
Old 09-14-2016, 08:31 AM
Walt Fricke's Avatar
If you have two equal (or nearly so) coolers, which have equal (or nearly so) air flow, you want to run them parallel. Heat transfer is a function of the temperature delta between the cooling air and the fluid. Having hotter fluid in both coolers means they both have the highest oil temps and thus the largest delta, and are the most efficient. See Carrol Smith on this and other race engineering subjects.
Doesn't Porsche do this with the water cooling radiators, one on each side?
Here is a picture of splitting the flow, and on a modified car it is not hard to do.
But on my stock class SC, with one Mazda cooler mounted in the center of the front valance under the bumper, I just ran them in series, with the better cooler (the Mazda) being the first in line, and the fender mounted Lemke getting the second shot. It is the less efficient cooler anyway, and some guys remove their fender mount cooler when they switch to a front mounted one. But it is easier in many ways just to leave it there. As long as you don't need to shed every ounce of weight it will help some.
Old 09-21-2016, 08:38 PM
Researched the mazda oil coolers, and some folks were concerned that they cause too much back pressure? Which mazda cooler did you use?
Looking on ebay, there are lots of oil cooler from BMW, Land rover, and others, that are 2-3 inches tall and 1-2 feet wide... Seems like many of these could be used?
I understand that a setrab 24inchx4inchx2inch would provide the best cooling, but that thing ain't fitting without some serious body work and fender work...
If one places a cooler in parallel, then the new coolers flow rate is less important as its flow is all "additive" to the original flow. Even if the flow to the new cooler is less than optimal, it stiff provides additional cooling, no?
Old 09-22-2016, 09:29 AM
Just googled... a 20 inch mazda oil cooler, about the same size as a setrab 172... is $100 new!!!
ALUMINUM Oil cooler MAZDA RX2 RX3 RX4 RX5 RX7 S1 S2 oilcooler
Is this the type you were using? I may end up going this route. Cheap enough that its worth trying. The Setrab is $600+ or so...
As the mazda is aluminum, welding on AN fittings should be pretty easy...
Anyone used this model before?
Old 09-22-2016, 09:34 AM
BoxsterGT's Avatar
Porsche Crest
Don't think you need to weld fittings to this Mazda type cooler. They appear to accept a straight threaded fitting (NOT PIPE) with a crush ring, similar in design to the Setrab.
Len
Old 09-22-2016, 11:07 AM
914 Geek
I believe that it is possible to wind up with less cooling in some circumstances when you add a cooler in parallel. If, for instance, the second cooler flows a lot more oil than the first, but does not cool as much (likely in part because the oil isn't in it very long) most of the oil will go through the new cooler. And you would wind up with less cooling.
That is the theoretical reason for Walt's caveats about "two similar coolers", I believe.
Of course, practice can and often does trump theory, so.... You can give it a try and let us know how it works!!
--DD
Old 09-22-2016, 11:47 AM
