It was in ~ok~ shape when I purchased it.
I have a lot more plans for the body before it goes to paint. thanks for the positive post. I just started talking to the guy that is going to be putting in the chassis bracing and cage. as soon as we have a plan/design that will e the next step. |
Platinum Member
Not my cup of tea.... but I think the lines would flow better now with slantnose or strosek fenders.
Good idea, I just purchased strosek fenders. Hope to have them by Friday. This will cut a lot of weight also.
updated pictures: ![]()
![]() Looking forward to your project.
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." Last edited by Dueller; 11-07-2009 at 06:58 PM.. |
Nice Project!! Do you have any pics of the chop as it was in progress?
Make My Day
Hmmm.... a hard top speedster. Maybe it'll grow on me.
I think a different tail and the Strosek fenders will make that happen.
74 911S Targa ROW Building Designer/Business Owner |
7.0:1 > 11.3:1 > 7.0:1
Very creative! I think your roof line is cleaner than the Mulholland RSR version. I have seen it and the line of that car was awkward. There was a 356 on one of these threads that used 550 style cooling ductwork and an enclosed rear window intake. I will post the photo, you might find that it is more fluid that using the quarter windows. As an industrial designer I am impressed when someone applies their creativity: even to something as iconic as the 911 design study. I will look foreword to watching your vision come to fruition!!
67' tangerine targa |
end of the weekend.
I need to get water pump gaskets. a MAP sensor test the alternator clean and test the injectors drop off the throttle body to be ported look for headers work on some custom plumbing. ![]()
To answer how I chopped the top.
I cut a 3" section out of the "A" pillar removed the "B" pillar and pie cut the "C" pillar. Then stretched the top and bottom "A's" to meet. I run 3/8 steel down the middle then started to weld back each layer. The B & C pillar's were much easier to rebuild one thing you have to remember is that the pillars are structural and you have to peal them like an onion then brace each layer as you put them back. it's not as easy as just cutting and pasting: ![]() ![]() ![]() ![]() ![]() ![]() continued below. Last edited by Rebel911; 11-08-2009 at 03:14 PM.. |
LS Exhaust option
Hi, I love the CHOP! Can't wait to see more.
I found a good set of headers that will clear the RH brackets, they are made by JBA Model 1850S-3 They were made for a LQ motor in a Suburban, but they fit great. See Pics below! Good luck. ![]()
11/9 - either the alt pulley or crank pulley is wrong.
everyday it is something... but the TB is at New Era. ![]() ![]() ![]() ![]() ![]() ![]()
Alternator alignment issue
Hi, I had trouble with my crank pulley / alternator alignment as well. My engine came from a corvette (LS6) and the crank pulley sites closer to the block than it would on a F Body camero/firebird LS motor. I think there are 3 different offsets for the LS crank pulley. Is it possible your motor came from a truck?
Friend of Warren
You have impressed the hell out of me! Nice work.
Kurt V No more Porsches, but a revolving number of motorcycles. |
he probability put the pulley on as well. You have a good source for pulleys? thanks! I can't wait for the new fenders to show up today... or tomorrow. I UPS next day aired them and this is what I get for updated tracking info: THE PACKAGE WAS LEFT IN A UPS FACILITY
So close. Wiring this weekend then put the engine in.
Dan, from Reactive Chassis, came over tonight to measure out and talk ideas for the chassis stiffing and cage. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
I have always liked ATI's Harmonic Balancers / Pulleys. Don't forget to buy a new bolt if you make the swap, the crank bolt is not re-useable on LS motors.
Keep the pictures coming. I am working on my fuel tank mount and radiator setup. I'll be curious to see how you route the cooling lines. I ended up running mine through the frame heating vents. ![]()
Looks like a fun build. I keep thinking you are putting the radiators in the back thus the side scoops.
