Please confirm this is the factory manual
Hi Folks,
Just got a factory manual on CD for the SC. Not sure if it's the manual or other supplements. Seems a bit sparse, doesn't even contain engine removal instructions.... Can someone confirm? Thanks in advance.
99 996 C2 Black, MY02 wheels, Aerokit Way too much fun! |
Yup, it is. That's the first page of the third volume. Vols 1-2 began in 1965 and carry thru 1971. That's where you will find "engine removal", for instance. Vols 3-6 cover model years 72-83 and provide only new information -- after all, removing the engine is basically the same.
Vols 1-2 are 2-3 inches thick. Vols 3-6 re about 1-1/4" thick. Vols 1-2 are broken up into sections ("E" for engine, for example). Vols 3-6 are organized by "code number" that matches your page above. |
Those are supplements to Vol I and II which you need.
Porsche updated Vol I until they came out with Vol II (they included a decal I for Vol I.) Vol I and II were updated through 1971. For the 72 model there was an update of four thin binders that covered everything new with the 2.4, 915, 925 and much more. I think there eventually were six binders in addition to Vol I and II. They were continually updated with supplements through 83? My six binders were too full and I added several more to thin things out. I am a firm believer that DIY Porsche people need all the different manuals; Factory, Bentley, Haynes, Clymer and more. Each presents the material slightly differently. Seeing it from different perspectives allows you to better understand when you have only seen the part or whatever once. Clearly the PET parts CD from out host is the best bargain around. Not only does it have all the part numbers but the exploded diagrams are invaluable to understanding the car. Even having all the manuals wont answer all questions. That is where Pelican is so valuable. I am a proponent of everyone making their own car-specific manual. It could include copies of the relevant pages from all the manuals and PET. It could include printouts from Pelican and other on-line resources. You can photo document everything you do. It can even be a scrapbook for invoices, timing sheets from DEs, copes of registrations, titles, etc. Whatever you want. This is not something to do all at once but a continuing project. It will increase the value of your car when it is time to hand it over to the next caretaker. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
There are six binders in total. Vols 1 and 2 were changed with the additional of "Supplements" that added pages to the end of the affected section (no pages were changed or added WITHIN the sections--they were simply added at the end.) Vols 3-6 were organized into the 10 code numbers, and new information was incorporated INTO the sections.
Vols 1-2 cover 911's thru 1971. As the page above shows, Vols 3-6 cover "from model 1972 on". They stopped updating Vols 3-6 after the 1983 model year, and 1984+ Carerras are covered by new Vols. Grady is right -- you need more than just the factory manuals. But the factory manuals are the ones to start with. |
Brian,
I think you are correct, there were only six binders Vol I&II and the four 72 supplements. I added more binders so each wasnt so full. I have a total of 12 and section 9 (wiring diagrams) needs to be split. Each supplement contained both new pages and replacement pages. Yes the new pages were typically added at the end of a section but not always. The replacement pages called for the removal of a prior page and its substitution with the replacement page. I have several binders full of replaced pages. Many times when adding replacement pages, I left the original page in place and put a diagonal line and the annotation that there was a replacement page. The Supplement Number (Roman numerals) are printed on each new and replacement page. Here is the index page for Supplement XXXII-USA dated December, 1974. " "(C) Dr. Ing. h.c. F. Porsche A.G. I suppose it would be useful to make a summery of all the supplements and a list of all the pages in a complete manual. Best, Grady Edit to fix typo Last edited by Grady Clay; 11-16-2005 at 05:38 PM.. |
Grady,
Good idea about splitting the electrical section (#9) into multiple binders. I think I will do that. Supplements for Vols 1 and 2 were always simply tacked onto the end of the affected secton. There was a single hard-paper divider, then a list of contents (which was always replaced with the next Supplement that affected that section), then new pages. Pages in the regular section were E-1 (engine section). The pages in the engine Supplements were numbered SE-1 and so on. Supplements for Vols 3-6 were as you show and describe them. |
I have a question about the early factory manuals. How can I tell if they have been updated with the supplemental pages? I don't know enough about the way Porsche updated and arranged the manuals. All I know is that for an SC you need vols 1,2,3,4,5,6 for complete information. I would like to have both the original and the updated pages, much like Grady has done. Is there any place that still sells the updates? Or anybody willing to share just the updates?
Lee,
Here is Supplement XII dated March 1968 (was unopened, still wrapped in plastic.) It consists of 87 pages 11 pages are replacement pages for existing pages and each has a revision date on it (all either 12/67 or 3/68). The remaining pages are added to the Supplement sub-section of each section in the manual. They are not dated or otherwise indicated that they are part of Supplement XII. Some are in color. I think the only way for anyone to insure they have all the pages is to make a list of page numbers and revision date (when listed) and check page-by-page. Chuck Stoddard once made such a list. I used to have a copy. "© Dr. Ing. h.c. F. Porsche A.G. Best, Grady |
So there was an unofficial list out there somewhere. Anybody have a copy of the list that Grady mentioned?
Are the updates still available? I have no idea if I have current or old pages. |
sorry duplicate message
Can you tell us where one could purchase a manual on CD?
83 SC |
I would like to know that also. I suspect this is a bootleg scan of the manuals. There are many with varying quality and completeness.
For many years we have lobbied Porsche to make the technical information widely available at a reasonable price. So far they only have offered the PET parts CD (about US$15) in compressed .pdf format to everyone. It is available from out host. I would like to see Porsche have available on CD all the Workshop Manuals, the Service Information (Technik) booklets, the little Spec Books, the Owners Manuals, the Campaign and Service Bulletins, and much more. It should be in the editable .pdf format so individuals can copy & paste to their own car specific manuals. It should be able to be expanded and copied to your hard drive so it works fast. I think they should offer the PET program for about double the compressed .pdf version. Why should Porsche AG and PCNA do this? 1) Good Will they are spending the goodwill that Professor Porsche, Ferry Porsche and many others have earned over many years. This is an inexpensive way to recoup some of what has been lost. 2) Reputation in the industry BMW has announced they will support every BMW motorcycle ever built. I understand they are headed to doing the same for every automobile. No manufacturer holds their customers hostage to technical information more than our beloved Porsche. 3) Good business sense the more old Porsches that are successfully being driven, maintained, and exposed to potential buyers of Porsche automobiles, the more Porsche can sell cars. If they are looking to keep selling Cayennes and possibly 4-doors and more, the more they will need the installed base of Porsche enthusiasts. 4) Good business sense with all the old 997s and earlier running about, the more parts can be sold. Porsche should free up the original specifications and license the re-manufacture of everything at reasonable prices. If they got 1’ on every part sold under license, they could greatly increase their net; income for no cost. If they were to continue their current greedy ways guess what. I think much of Porsches current philosophy is a direct result of having dug a big financial hole with the Cayenne. Many were predicting the demise of PAG when the development cost was known. I wont fault Porsche for digging themselves out of that hole. Now it is time to earn back the lost goodwill. Best, Grady
Who has 911 Workshop Manual Supplement cover pages?
I have a few, here are the pages included in them. From this we can reconstruct the sequence of additions to the 65-83 manual. Supplements to 911 Workshop Manual - XII, March 1968 This supplement contains the following pages: Index to Supplements for Group E SE17 SE26 Index to Supplements for Group R SR17a SR28a SR28b SR35 SR138 SL1 SL17 SM7 STD7 STD12 Revised Pages: E37 E38 E97 E98 SE3 SE4 SF1 SF3 S7 S8 R75 R76 R83 R84 R87 SR21 SR22 T17 T22 Best, Geady
Supplements to 911 Workshop Manual - XIII,
October 1968 This supplement contains the following pages: E87 E88 E93a E93b SE27 SE31 SF7 SF9 SS1 SS9 SW1 ST7 ST10 ST15 ST20 STRA7 STRA20 W13 Revised Pages: SR33 STRA3 STRA4 Best, Grady
Supplements to 911 Workshop Manual - XIV,
October 1968 This supplement contains the following pages: Index to Group B B1 B103 (Existing pages of Group B should be deleated.) In addition: 2nd register for supplements to Workshop Manual 911 Best, Grady
Supplements to 911 Workshop Manual - XV,
April 1969 This supplement contains the following pages: SS1 SS42 SR17b SR58a SR58b SR139 SR158 SW3 ST21 St27 S97a Contents Supplements to Group B SB1 SB28 Contents Supplements to Group L SL19 SL33 SL37 SL45 SM9 SM11 STD13 STD30 Replacement sheets: S13 S14 S33 S38 S47 S48 Contents Supplements to Group S R53 R56 R61 R62 R83 R87 Contents Supplements to Group R SR65 SR68 SR81 SR84 SR97 SR98 SR101 SR104 SR137 SR138 Contents Supplements to Group T ST11 ST14 Best, Grady
Supplements to 911 Workshop Manual XVI,
November 1969 This supplement contains the following pages: SR28c SR28k Replacement sheets: ST11 Best, Grady
Supplements to 911 Workshop Manual - XXX,
October 1974 Contents: For volumes III and IV: 1 5.1-1/1 to 5.1-1/2 2 2.2-2/1 to 2.2-2/8 9 0.1-1/5 to 0.1-1/7 6.1-1/3 6.4-2/1 Revised Pages: 2 2.1-1/7 to 2.1-1/8 3 0.2-1/3 to 0.2-1/4 6 4.1-1/3 to 4.1-1/4 9 0.1-5/1 Best, Grady
Semper drive!
Grady,
Sent you a PM but was told your mailbox was full. Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Grady, thanks for putting together the info. I did not realize there were that many pages involved. I know that there is little if any logic to what order Porsche arranged these updates. It looks like you have updates 12-16 then jumps to 30. Did they just change the way they numbered the updates or were there actually 14 more updates?
