Banned
outer CV boot replacement - secret handshakes?
I'd done my inner boots when I had my motor out, and have been DREADING this day since I got the car a meelyun years ago - outer boot has gaping hole (think: Ronknees gape!!!).
Pretty certain I caught it right away, there's not a drip of grease thrown out of it yet - phew.
I've searched a few threads on the 911 tech forum but figured I'd ask my bestest budz here - how do you guru's like to tackle an outer boot on your 930? Have to pull the whole axle?
Any insight bra-clasp secret handshakes appreciated.
Found the hole (!!!!) whilst under there locating my massive fuel leak - burst a line... pulling into my driveway! Talk about great luck - I'll take it! Geesh. Right onto steaming hot header - f'n SPOOKY!
Len's dropping me off a new line tomorrow - how cool is he?
Stoooooopid banana arm has an upright 'edge' on top that's sharp and when the car is lowered back to the ground the fuel line rubbed against it and perf'd. Awesome. I must have routed the line wrong back when I'd installed Len's main tunnel lines - sigh.
anywho..........
Old 09-11-2016, 08:18 AM
I can't remember if the half shaft will compress enough to allow you to loosen the outer bolts to allow it to release and come down towards the floor enough to push a new boot on or not. I guess you can try, and if not, you know whats your gonna half ta doo. Best make sure the CV joint is good, tho, and since you're in there, re-grease it up like you know Rawknees likes it...
Old 09-11-2016, 08:46 AM
Yecch. Did this somewhat recently. Axle out. Make sure to brake kleen the bolts and go at them super square with a quality socket. You don't want to round one of the outside bolts out, ever. Parts washer helps but disassembly and repack is a filthy job. Latex gloves etc, Doctor.
And you know this, but recheck bolts after 50-100 miles.
Ken
1986 930 2016 R1200RS
Banned
Ugh. Thanks.
No way around axle out eh?
Old 09-11-2016, 10:17 AM
xbmwguy's Avatar
Gotta pull em pauly!!!!
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp
Old 09-11-2016, 03:03 PM
Banned
argh - bummage
"yay".
I'll pull 'em, but that'll PALE in comparo to all the violent doublehand'r pullin Rawknees' got goin on... could start a large fire, he could!
Well... least by posting this and not just surfing the archives here I pulled Geoff, Kenster, and FRANK out of the woodwerk - really great to hear from YFF's... hope you're all schwell!!!
Old 09-11-2016, 06:33 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Paul, IcyHot has already offered to help with yer ball(bearing) and rod lubage, so one must ASSume he'll lend a hand (literally) with the pulling, too!!!
Old 09-11-2016, 07:11 PM
It's not hard and I still need to do it since getting new boots...
I spray off the flinged grease under there with spray can engine cleaner and a garden hose.
Get the back of car as high as you can on jackstands, lay on your back under there, use a long pry bar between two allen head bolt heads and the floor or bottom of the car to keep it from turning and remove the other allen head bolts with socket wrenches.
Or you could use the emergency brake.
Old 09-11-2016, 07:30 PM
Originally Posted by rawknees'turbo View Post
paul, icyhot has already offered to help with yer ball(bearing) and rod lubage, so one must assume he'll lend a hand (literally) with the pulling, too!!!
lol
Old 09-11-2016, 08:48 PM
Originally Posted by JFairman View Post
It's not hard . . .
Something Paul is very used to hearing from the mouths of wimmiz folk; followed by a certain pharmaceutical recommendation !!!
Old 09-11-2016, 09:01 PM
T77911S's Avatar
i just did all 4 of mine,
just pull the shafts out, its not that big a deal.
I remove the wheels and use a LONG extension for the inner ones.
when putting back on, put the outer side on first.
take note of the CV joint.
the groove goes to the outside
the "step" on the inner flange goes to the center of the axle
the big side of the cage goes to the outside. (I did not notice on mine)
get the KN boot from here. it has a groove on the big end that fits onto the flange
you can get a set of the clamp crimp pliers from advance for $10
I did not put a clamp on the inside (small end) of the boot.
I used swepco 101. I liked it because it was kind of sticky
one tube will do 4.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-12-2016, 04:36 AM
Alexm930's Avatar
Paul, I am doing this job also. Found a boot torn outside driver side. Like they said axle has to come out. It is not that bad a job. Good luck.
Speedlimits are for the guidance of wise-men & the obedience of FOOLS!
Old 09-12-2016, 05:46 AM
Banned
thanks much guys
more a kick in the deek than anything (Rawknees is JEALOUS of such!)
Len dropped me my fuel line today and I got the burst one out so got that goin for me heh heh
Alex - come do my boot! Ha! Yup, outer / driver here too. Ginormous gaping Rawknees sized hole.
Still trying to plan a drive, likely VT in fall - stay tooned
Old 09-12-2016, 10:37 AM
Originally Posted by krasuskyp View Post
Alex - come do my booty! Ha! Yup, outer / driver here too. Ginormous gaping Rawknees sized hole.
Fixed for accuracy - yer welcome!
And like so?!?!?!
Old 09-12-2016, 11:25 AM
Banned
A'ight - so pulling my axle (!) Proved to be a 7min endeavor and nowhere near as bad as I'd been unnecessarily imagining. Thought I'd heard the outers were a hoor but t'was a snap.
SC John'd aptly reminded me that I need the paper gasket that goes betwixt ze shaft and ze joint. Doh. Not in the kit.
Fak.
Is it OK to cut one out of gasket stock, or best be patient to order right one?
Would thunk it'd be ok to cut one.
Also got my new Len fuel line on, he dropped one off @ my exit Monday - he's the MAN!
TIA, muuffuukkaahhzz...
Old 09-17-2016, 02:24 PM
1987 930 CV joints have a pressed on steel cap on the flange side, there is no gasket on them. The older thicker CV joints had no cap and they should have the gasket or grease eventually flings out and water can get in.
Old 09-17-2016, 02:38 PM
Banned
Nice, thanks Jimbo!
Full steam ahead then!
Old 09-17-2016, 03:06 PM
MikeD930's Avatar
^^^JF is correct...your CV joint should not have any gaskets. When I rebuilt my CV joints I applied thin layer of Hylomar sealant between the metal cap(s) and main body of CV joint to keep the grease in.
MikeD '87 930
Old 09-17-2016, 03:10 PM
Banned
Thanks MikeD!
Old 09-17-2016, 03:45 PM
Banned
annnnnd... I find splitting in the valley of the 2yr old (!! !! !!) boot on the other end of the f'n axle. Sonofa.......
Old 09-18-2016, 05:29 PM
