Thanks,
i am always willing to pass on "bad" ideas
Rick
1985 911 Targa RarlyL8 center outlet muffler & waste gate dump,GT30R turbo,.9 bar spring,Canems programable DME, around 400 wheel hp SOLD BUT NO FORGOTTEN
Old 09-20-2009, 12:54 PM
Update!!
Car is on the road, put about 30 miles on yesterday evening. Have not gone over 3200 rpm, but the power is intense. For some reason I cannot upload pictures, hopefully my son can upload from college this evening.
Thanks to Mike Gariga for finishing it up, I would like to think I helped.
Rick
Old 11-15-2009, 08:28 AM
skinnerd's Avatar
Yes....need many more pics and details of what transpired in the last couple months.
Great project!
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 11-15-2009, 08:47 AM
Pictures of the final product...
2008 VW R32
1995 Jeep Wrangler (YJ)
Old 11-16-2009, 06:18 AM
Crotchety Old Bastard
RarlyL8's Avatar
Damn Rick that's nuts!
Old 11-16-2009, 05:49 PM
sjf911's Avatar
Beautiful! Good job.
A couple of questions. Are those GSF headers and IC? How are you handling the turbo oil return? Also, I thought the C2 gaskets were cut into the cylinders, is there another type? How much advance are you running?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-16-2009, 07:52 PM
1966 - 912 - SOLD
lane912's Avatar
i want to put one of those in my 66' 912 for a conversion!!!!!!
that is awful perty, good job
Old 11-16-2009, 08:03 PM
Thanks Brian - the exhaust is really sweet
The headers and IC are both from GSF.
Turbo oil return is going to the oil drain plug on the bottom of the case
C2 turbo gasket are not cut into the cylinders
Timing is handled by the Protomotive chip you would have to ask Todd Knighton
Thanks for the comments.
Rick
Old 11-17-2009, 03:34 AM
Jammo's Avatar
Hi Rick,
I have to agree with everyone on this one - fantastic work - and I have been watching with great interest.
Have you used the standard 3.2 MAF?
Kind Regards
Jammo.
Old 11-19-2009, 12:38 PM
skinnerd's Avatar
Really is a sweet looking engine.
Enough power I am sure....but not over the top.
Like it a lot!
Doug
Old 11-19-2009, 09:21 PM
Hi Jammo,
Thanks for the comment - yes so far it is the stock 3.2 MAF.
Thanks Doug
Rick
Old 11-20-2009, 02:45 AM
Rick,
Any chance for an update?
How is it running? Any teething issues?
Very, very nice and clean. WOW!
Thx.
Old 05-30-2010, 12:54 PM
Hey 911st,
I have just had the valves adjusted at 1000 miles. After that I found out I have a miss at full throttle above 5000 rpm and I am trying to figure out what it is. I am going to pressureize the intake system and see if I have any leaks. I installed a 044 Bosch fuel pump so I do not think it is lack of fuel. Still trouble shooting.
Up to 5000 rpm the power is very intense.
Thanks,
Rick
Old 05-30-2010, 06:40 PM
Such a nice job and clean install.
I like how the IC is a bit to the right to make room for the air filter.
Can who ever fabed the IC and snorkel reproduce thouse easly if some one wnated one?
I assunm you have a wide band on it. Is that telling you anything?
Did you go to 944T injectors?
Could your injectors be going on you at the higher pressure?
The best!!!
Old 05-31-2010, 07:55 AM
911st
I fabbed up the intake out of 3" aluminum, i can give you a drawing of what i did if you like.
The vertical stack from the turbo to the intercooler is a GFS part as is the intercooler
No, I do not have a wide band on it yet.
The chip is programed for stock injectors, they are original and were fine, they may be the problem
Thanks,
Rick
Old 05-31-2010, 02:59 PM
Just my opinion but you have way to much in this to risk not verify your AFR's.
Who is GFS please?
Dose the air filter tuck up under the parcel shelf so it dose not get rain directly on it?
Do you think the IC might fit under a duck tail or a 3.2 Carrera tail with limited mods?
Thx.
Old 05-31-2010, 04:13 PM
I agree with you and it will be done. just no time right now
www.goingsuperfast.com
Yes. the air filter does fit up under the parcel shelf.
I have read of people doing it, I had a stock Carrera wing and had to change to a turbo wing for my installation
Rick
Old 06-01-2010, 02:49 AM
Here is a link to Paul Rodelo's 930 with a duck tail
http://forums.pelicanparts.com/porsche-cars-sale/390417-fs-930-rsr-excellece-featured-show-winner-1st-45k.html
Rick
Old 06-01-2010, 02:57 AM
Thx Rick.
The best!
Old 06-01-2010, 06:16 AM
Hi Rick:
Going the same route as you, as I have the stage I from protomotive and moving to stage II due to high oil consumption and smoking. My question is: Do you had to cut grooves on the heads to fit the C2T gaskets, or are they just sandwiched between the head and cylinder?
Thanks,
Francisco
Old 11-08-2010, 02:26 PM
