Banned
Going to see a 996, oil analysis report....
I'm going to see a 996 tomorrow. 100k, has had IMS done with the LN bearing at 75k.
There is a oil analysis report in the photos. Report sounds reasonably positive. Curious if anyone knows how to read the numbers, and can tell me what they think.
https://columbus.craigslist.org/cto/d/columbus-2001-porsche-911-carrera/6868074240.html
Old 05-04-2019, 03:58 PM
Banned
Registered Cruiser
jorian's Avatar
That is a good looking 996.1. Honest looking and seller sounds trustworthy. Don’t have any experience with the Blackstone guys but here is a link to a legend of the reports.
https://www.blackstone-labs.com/services/report-explanation/?session-id=3v520g45c14e0t55wtoiad45&timeout=20&bslauth=&urlbase=https%3A%2F%2Fwww.blackstone-labs.net%2FBstone%2F(S(3v520g45c14e0t55wtoiad45))% 2F
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 05-05-2019, 06:59 AM
biosurfer1's Avatar
What happened to the manuals? Looks like they fell out of the glove box and we're run over several times
Old 05-05-2019, 08:07 AM
Team California
speeder's Avatar
I'd be more concerned about the K&N air filter. That's usually an automatic deal-killer for me on anything other than a full race engine or some swamp donkey vehicle that just needs to run for now. Why on earth would anyone want to modify their intake filtration to suck in more dirt? Do they think that piston rings really last longer w a little dirt bath?
Denis
Old 05-05-2019, 09:14 AM
cycling has-been
bkreigsr's Avatar
That 'first' report is almost 2 years old.
Any chance you could get a updated sample in to Blackstone?
How many miles since the first sample?
Bill K
Old 05-05-2019, 10:36 AM
Banned
Bill K
Date on the report is 10/19/2018.
Old 05-05-2019, 12:09 PM
canna change law physics
red-beard's Avatar
What on earth oil are they using? Who needs a 6.0 TBN in car? Do you know which oil was used?
TBN is the measure of anti-acid additive package.
James
Red-beard for President, 2020
Old 05-05-2019, 01:21 PM
brainz01's Avatar
Per the UOA report, looks like he was using M1 0w40 which is factory spec. I don’t recall seeing moly in M1 0w40, and the zinc and phosphorous look a little low, so I can’t help but wonder if it was a different oil. The iron is on the high side, but not catastrophically so. Otherwise, the report looks good for the miles.
The TBN of 6 is healthy, M1 starts around 10 or 11 if I recall. But the viscosity looks low, though that’s the usual complaint for why many think that M1 0w40 isn’t enough oil for the M96 engines. The RL forums are filled with folks suggesting more expensive/thicker oils that are more shear resistant than M1 0w40.
Old 05-05-2019, 01:57 PM
Cracked heads and intermix are on the horizon for that car (and all 3.4's)
Great car but.....
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 05-05-2019, 02:12 PM
Banned
Great car but.....
There is a car in TN on the market. $8000. Has a cracked head. Owner does not want to fix.
Old 05-05-2019, 03:18 PM
red-beard's Avatar
That seems really high for a gasoline engine. Diesel I would understand. On our Landfill gas machines, the TBN starts around 5.5-6. And we have H2S in the gas, which causes acidification when it burns.
James
Old 05-05-2019, 04:35 PM
Now in 993 land ...
aigel's Avatar
No matter what the comment says, the iron is higher than the average. The average was taken at around 4k miles, so the iron should be 1.5x or less. 4k average is 11ppm, so it should be 16ppm, yet it is more than double at 25. I would be concerned about it. Once the genie is out of the bottle, I couldn't help but worry about data. Of course, most cars you don't see this and wouldn't even know. If the engine was rebuilt, I'd say no problem as they may use different parts / tolerances than stock, but a stock engine ...
G
81 SC (sold)
Old 05-05-2019, 05:02 PM
Non Compos Mentis
Oil analysis is popular with the airplane guys. Blackstone has a good reputation.
One report is usually worthless. Where oil analysis shines is seeing trends.
When one has several reports that pretty much mirror prior reports, and the next one shows something deviating from the norm, it tells one where to look for the issue, or in the case of large amounts of ferrous metal, impending doom. Better to ground the airplane before a catastrophic failure in flight.
With this one report, there is no baseline from which to compare.
Old 05-05-2019, 07:00 PM
Now in 993 land ...
aigel's Avatar
Note that the comment guy says "YOU FOUND SOME MATERIAL IN THE OIL FILTER". Apparently the owner sent the oil analysis after being concerned finding shavings or something ...
I have NEVER found material in the oil filter on any of my vehicles. Dozens of open element filters and a half a dozen cut open cans as well.
G
81 SC (sold)
Old 05-05-2019, 08:18 PM
Did you get the memo?
onewhippedpuppy's Avatar
G
I've found metallic particles in the oil of quite a few different cars, it's pretty normal. Larger pieces are signs of trouble.
As for the 996 it looks like a nice honest car. I would ask about the clutch, I assume it was replaced at the same time as the IMS but it can't hurt to check. If everything checks out, buy it and enjoy. They are great cars that are still followed by a stigma largely based on ignorance.
‘07 Mazda RX8-8
Old 05-06-2019, 02:50 AM
